Ifort 19.0.2 with -O2: Compilation hangs when allocating Array to 0-size
Diehl__Martin
I am using the newest Ifort compiler and the compilation hangs (running forever) when I compile with -O2. I could narrow it down to a few lines of code where an array is allocated to zero size. The following example demonstrates what I am doing, but compiles without any issues. The actual code (part of a bigger project) is attached. It requires some libraries and MPI to build/
program allocate_zero
  implicit none
  type :: tParameters
    real, allocatable, dimension(:,:) :: &
      gdot0_slip, &        !< reference shear strain rate for slip
      gdot0_twin
  end type
 type(tParameters), dimension(:), allocatable :: param
 integer :: i
 allocate(param(3))
 do i = 1, 3
 associate(p => param(i))
   if (i > 2) then
    allocate(p%gdot0_slip(0,0))
   endif
 end associate
 enddo
end program
Williams__Ben
I only have access to 19.0.0.117 at the moment so can't test your example code properly in 19.0.2- for clarity though, does the example hang? All you say above is it compiles correctly. If the example does hang then there's a few things you could try: 1) remove the associate block and explicitly state param(i) in the allocation 2) remove the do loop and explicitly state param(3) in the allocate. 3) allocate to size 1,1 - assuming you haven't done this already. If that works it would indicate the presence of a bug for zero-sized arrays. 4) check stat on the allocate (doubt it'll ever leave if it's hanging though) 5) check it works with -O0 or -O1. I doubt any of these suggestions will change the hang but if they do then it might indicate where the problem is more specifically.
Juergen_R_R
Valued Contributor II
I don't see any hanging of the program that you posted, neither with -O2 nor without. You mentioned MPI, maybe that is related to MPI? Or is the problem only in the longer example that you attached.
Diehl__Martin
Thanks for the help.
To make sure, I cannot reproduce the behavior with a minimal working example.
I have investigated the behavior in more detail and figured out that is is related to the use of the following function which is called after the code I erroneously identified as the culprit in the original post:
!> @brief vector expansion
!> @details takes a set of numbers (a,b,c,...) and corresponding multiples (x,y,z,...)
!> to return a vector of x times a, y times b, z times c, ...
pure function math_expand(what,how)
 implicit none
 real(pReal),   dimension(:), intent(in) :: what
 integer, dimension(:), intent(in) :: how
 real(pReal), dimension(sum(how)) ::  math_expand
 integer :: i
 if (sum(how) == 0) &
   return
 do i = 1, size(how)
   math_expand(sum(how(1:i-1))+1:sum(how(1:i))) = what(mod(i-1,size(what))+1)
 enddo
end function math_expand
I use this function in 6 files and I causes problems only in 2 of them. As soon as I comment it out, it compiles.
It is always used like
prm%burgers_twin = math_expand(prm%burgers_twin,prm%Ntwin)
i.e. the left side gets reallocated according to the return value of the expansion function.
