Ifort LAPACK and Fedora core 2
Deleted_U_Intel
I have just installed ifort under fedora core 2 but it
doesn't work properly.
I can compile and run simple prgorams.
I can compile and run the tests on BLAS
but when I try to compile LAPACK (downloaded form netlib)
it hangs. Well I should say that it builds the
executables successfully but hangs when it tries to execute them.
It hangs on to start with on ./testslamch.
I tried compiling with and without optimization but with
no success.
Any suggestions ?
Paul
mbkennel
The problem is a common one.
The issue is that the low-level machine routines which try to
detect machine floating point parameters are upset by modern optimization. (e.g. SLAMCH.F) I have found that using the -mp1 option seems to help.
on OPTS I have
OPTS=-Vaxlib -O3 -unroll -mp1 -static-libcxa
and
NOOPT = -mp -O0 -fltconsistency -fp_port
