29578 Discussions
Ifort and Xcode 3.2.4 compatibility question
Wich
I have just seen that the update to Xcode 3.2.4 is available through the software update, so I would like to know if there are known issues(like with versions 3.2.2 and 3.2.3 in the past) with the latest compiler version or I can update safely?
Thanks for the answers.
Ron_Green
Go ahead and update, I've been running 3.2.4 for a while w/o issues. But we still have an open bug report with Apple on their linker. If your code uses SELECT CASE statement(s) or if you have C code with SWITCH statements, add compiler option -use-asm to work around the linker bug in 3.2.2, 3.2.3 and 3.2.4.
ron
