29341 Discussions
Ifort bug: Loosing polymorphic information for overriden operators
Bálint_A_
Dear Intel developer,
The ifort 16 compiler (16.0.0 20150815) seems to generate non-standard conforming code, when a polymorphic type with an overriden operator is stored as a pointer within a derived type. The self containing example below demonstrates the issue for the comparison operator: the code calls the comparison operator of the basetype, instead of the extended one. Similar error happens if the assignment operator is overriden, so I guess, the problem is operator independent.
Bállint
module typedefs
  implicit none
  type :: Base
  contains
    procedure :: isEqualTo => Base_isEqualTo
    generic :: operator(==) => isEqualTo
  end type Base
  type, extends(Base) :: Extended
    integer :: data
  contains
    procedure :: isEqualTo => Extended_isEqualTo
  end type Extended
contains
  function Base_isEqualTo(this, other) result(isEqual)
    class(Base), intent(in) :: this
    class(Base), intent(in) :: other
    logical :: isEqual
    select type (other)
    type is (Base)
      isEqual = .true.
    class default
      isEqual = .false.
    end select
    print *, "Base_isEqualTo:", isEqual
  end function Base_isEqualTo
  function Extended_isEqualTo(this, other) result(isEqual)
    class(Extended), intent(in) :: this
    logical :: isEqual
    select type (other)
    type is (Extended)
      isEqual = (this%data == other%data)
    class default
      isEqual = .false.
    end select
    print *, "Extended_isEqualTo:", isEqual
  end function Extended_isEqualTo
end module typedefs
program test
  use typedefs
  implicit none
  type :: BasePtr
    class(Base), pointer :: ptr
  end type BasePtr
  type(Extended) :: myExt1, myExt2
  logical :: isEqual
  type(BasePtr), allocatable :: array(:)
  myExt1%data = 1
  myExt2%data = 1
  allocate(array(2))
  allocate(array(1)%ptr, source=myExt1)
  allocate(array(2)%ptr, source=myExt2)
  ! This should invoke Extended_isEqualTo, but it calls Base_isEqualTo instead
  isEqual = (array(1)%ptr == array(2)%ptr)
  print *, "Main:", isEqual
end program test
FortranFan
I'm not convinced it is an issue with the compiler.  Prima facie, Intel Fortran appears standard-conforming even though it doesn't work as you want it to whereas gfortran does.  I vaguely recall discussions along these lines on this forum and elsewhere; I'm unable to track down any details at present.  But perhaps you can follow up with the standard and point to relevant sections that indicate the behavior should be as you indicate.  Given the polymorphic pointer component, I think the standard requires you to do something along the following lines given how you have defined the Base and Extended types and in that case, Intel compiler will work as you would like it to:
program test
   use typedefs
   implicit none
   type :: BasePtr
   end type BasePtr
   logical :: isEqual
   myExt1%data = 1
   myExt2%data = 1
   allocate(array(2))
   select type ( ptr => array(1)%ptr )
      type is ( Extended )
         isEqual = (ptr == array(2)%ptr)
      class default
   end select
end program test
Upon execution with Intel Fortran,
 Extended_isEqualTo: T
 Main: T
Press any key to continue . . .
Of course, the above change is lame but I think that is what it would take with polymorphic components of the 'class(Base)', a penalty incurred with runtime polymorphism.  But I may be wrong about this, would like to learn better.
I'm looking at this. I think it should work. More later.
Bálint_A_
I am quite bad in reading the words of the standard, so I can not point out which part of it is violated by the code above. Thanks for the working example. Actually, although it may work fine, I really need run-time polymorphism, as I am designing collections with elements of arbitrary types.
Also, note, that if I replace the call
with
isEqual = array(1)%ptr%isEqualTo(array(2)%ptr)
(without any select type statement around) the code works as expected. So, ifort knows how to do proper run-time polymorphism, but forgets it, if it is invoked via an overridden operator.
I think this is the same general issue as https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/623372
Here is what the standard says regarding defined operators:
5 A function defines the binary operation x1 op x2 if
 (1) the function is specified with a FUNCTION (12.6.2.2) or ENTRY (12.6.2.6) statement that specifies
 two dummy arguments, d1 and d2,
 (2) either
 (a) a generic interface (12.4.3.2) provides the function with a generic-spec of OPERATOR (op),
 or
 (b) there is a generic binding (4.5.5) in the declared type of x1 or x2 with a generic-spec of
 OPERATOR (op) and there is a corresponding binding to the function in the dynamic type
 of x1 or x2, respectively,
 (3) the types of d1 and d2 are compatible with the dynamic types of x1 and x2, respectively,
 (4) the type parameters, if any, of d1 and d2 match the corresponding type parameters of x1 and x2,
 respectively, and
 (5) either
 (a) the ranks of x1 and x2 match those of d1 and d2 or
 (b) the function is elemental, x1 and x2 are conformable, and there is no other function that defines
 the operation.
In this case, there is a generic-spec of OPERATOR(op) and a corresponding binding in the dynamic type of array()%ptr. I added this to DPD200409351.
