Ifort with LAM-MPI
alexismor
Hi everyone,
I was wondering if there was a way to use mpiifort along with LAM/MPI deamons instead of MPD ones. The problem with using MPD is that I don't have the right version of python installed on all the nodes of my cluster, and I really can't do very much about this since I'm not the system administrator for this cluster.
Alexis
TimP
You certainly can use lam mpi with ifort, but not with mpiifort. Most likely, you will need to build lam with ifort and install it across the cluster. This would seem to be possibly as much trouble as reconciling the python versions across the cluster.
