29375 Discussions
Implicit none in abstract interfaces
Juan_Senent
I'm getting a strange error when I use implicit none in the definition of abstract interfaces. The following code
module test_class
type, abstract, public :: type_test
procedure(func_test), pass, pointer :: get_f=>null()
end type type_test
abstract interface
function func_test(eq, x)
import type_test
implicit none
class(type_test), intent(in) :: eq
real(8), intent(in) :: x
real(8) :: func_test
end function func_test
end interface
end module test_class
generates the error:
#6404: This name does not have a type, and must have an explicit type. [GET_F]
#7367: The data value NULL() can only be assigned to a Fortran POINTER.
but when I remove the 'implicit none' in 'func_test' the error disappears.
We have also seen that if there are more than one function (or subroutine) in the abstract interface declaration, as long as the first one does not have the 'implicit none' statement, the rest can have it or not and the program compiles fine.
Any help on this issue would be greatly appreciated
thanks
Juan
I've seen something like this before, a compiler bug. I will look into it but won't be able to do so until next week.
Jacob_Williams
New Contributor III
FYI: This bug is still present in the latest compiler version (v12 Update 6).
Jacob_Williams
New Contributor III
It's still there in v12 Update 8.
Sorry for the delay in following up on this. The problem is escalated as issue DPD200177491. I suggest removing the IMPLICIT NONE as a workaround for now.
This has been fixed for a future release. How important is it to have the fix in a 12.1 update?
