Take the very new and the very old, and just for fun mix them together and see what happens.
PROGRAM p
IMPLICIT TYPE(t)(a)
INTEGER, PARAMETER :: i = 99
TYPE t(k)
INTEGER, KIND :: k = i
INTEGER :: comp
END TYPE t
TYPE(t) :: b
! a = t(1) ; b = t(1) ! Spurious error #8212
PRINT *, a%k, b%k
END PROGRAM p
>ifort /check:all /warn:all /standard-semantics /stand implicit.02.f90 && implicit.02.exe Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.108 Build 201407 26 Copyright (C) 1985-2014 Intel Corporation. All rights reserved. implicit.02.f90(10): warning #6717: This name has not been given an explicit type. PRINT *, a%k, b%k -----------^ Microsoft (R) Incremental Linker Version 10.00.40219.01 Copyright (C) Microsoft Corporation. All rights reserved. -out:implicit.02.exe -subsystem:console implicit.02.obj 0 99
Amusing. Thanks.
I believe that the error 8212 in the commented out line is correct. With t(1), you are specifying a value for the type parameter k, but not for the component comp. However, this brings up different issues that are compiler bugs when I fix this by changing these to t(comp=1):
First, the compiler is not applying the implicit TYPE(t) to variable a. Second, for the assignment to b, the compiler complains that the types don't match, which is not correct.
I have escalated this as issue DPD200362973.
With the 8212 thing, isn't the syntax with a specification for the type parameter t(expr_for_k)(expr_for_comp) , the first set of parens belonging to the derived-type-spec syntax rule and being optional?
Yes, that's right - I missed that.
The error 8212 is escalated as DPD200362993. This was a real head-scratcher for me as I thought at first that there was a syntax ambiguity in the language. I caught myself, though, and realized that there isn't. If the (1) was intended to be a type parameter, the constructor would have to be written as t(1)().
This has been fixed - I expect the fix to appear in update 2, planned for February.
To be clear, I expect both problems reported here to be fixed in Update 2.
When the paint on update two is touch dry, give it a whirl on the following maliciousness.
PROGRAM p
IMPLICIT NONE
! TYPE :: t(k)
! INTEGER, KIND :: k
! END TYPE t
CONTAINS
SUBROUTINE s
IMPLICIT TYPE(t(1,2))(a)
! CLASS(t(2,3)), ALLOCATABLE :: b
TYPE :: t(j,k)
INTEGER, KIND :: j
INTEGER, KIND :: k
END TYPE t
END SUBROUTINE s
END PROGRAM p
with 15.0.1 and /check:all /warn:all /standard-semantics it ices.
Because of the ice I didn't quite get there, but the ability to have a forward reference of sorts (in the implicit statement) to a type that may or may not be defined in the current scope looked like a fun little problem to resolve.
Looks like we fixed this one too. It no longer reproduces with our latest sources.
