29285 Discussions
Implict typing and defaulted derived type kind params
IanH
Take the very new and the very old, and just for fun mix them together and see what happens.
PROGRAM p
  IMPLICIT TYPE(t)(a)
  INTEGER, PARAMETER :: i = 99
  TYPE t(k)
    INTEGER, KIND :: k = i
    INTEGER :: comp
  END TYPE t
  TYPE(t) :: b
!  a = t(1) ; b = t(1) ! Spurious error #8212
  PRINT *, a%k, b%k
END PROGRAM p
>ifort /check:all /warn:all /standard-semantics /stand implicit.02.f90 && implicit.02.exe
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.108 Build 201407
26
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
implicit.02.f90(10): warning #6717: This name has not been given an explicit type.
  PRINT *, a%k, b%k
Microsoft (R) Incremental Linker Version 10.00.40219.01
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:implicit.02.exe
-subsystem:console
implicit.02.obj
 0 99
Steven_L_Intel1
Amusing.  Thanks.
Steven_L_Intel1
I believe that the error 8212 in the commented out line is correct. With t(1), you are specifying a value for the type parameter k, but not for the component comp. However, this brings up different issues that are compiler bugs when I fix this by changing these to t(comp=1):
First, the compiler is not applying the implicit TYPE(t) to variable a. Second, for the assignment to b, the compiler complains that the types don't match, which is not correct.
I have escalated this as issue DPD200362973.
IanH
With the 8212 thing, isn't the syntax with a specification for the type parameter t(expr_for_k)(expr_for_comp) ,  the first set of parens belonging to the derived-type-spec syntax rule and being optional?
Steven_L_Intel1
Yes, that's right - I missed that.
Steven_L_Intel1
The error 8212 is escalated as DPD200362993. This was a real head-scratcher for me as I thought at first that there was a syntax ambiguity in the language. I caught myself, though, and realized that there isn't. If the (1) was intended to be a type parameter, the constructor would have to be written as t(1)().
Steven_L_Intel1
This has been fixed - I expect the fix to appear in update 2, planned for February.
Steven_L_Intel1
To be clear, I expect both problems reported here to be fixed in Update 2.
IanH
When the paint on update two is touch dry, give it a whirl on the following maliciousness.
PROGRAM p
  IMPLICIT NONE
!  TYPE :: t(k)
!    INTEGER, KIND :: k
!  END TYPE t
CONTAINS
  SUBROUTINE s
    IMPLICIT TYPE(t(1,2))(a)
!    CLASS(t(2,3)), ALLOCATABLE :: b
    TYPE :: t(j,k)
      INTEGER, KIND :: j
      INTEGER, KIND :: k
    END TYPE t
  END SUBROUTINE s
END PROGRAM p
with 15.0.1 and /check:all /warn:all /standard-semantics it ices.
Because of the ice I didn't quite get there, but the ability to have a forward reference of sorts (in the implicit statement) to a type that may or may not be defined in the current scope looked like a fun little problem to resolve.
Steven_L_Intel1
Looks like we fixed this one too. It no longer reproduces with our latest sources.
