29642 Discussions
Impossible to associate pointer to array from submodule.
Daniel_Dopico
1>D:\temp\Fallo_compilador3\restricciones.f90(27): error #7994: A use associated object that has the PROTECTED attribute shall not appear as a target in a pointer-assignment-stmt.   [FI]
The mentioned error is obtained with the following piece of code in Intel Parallel Studio XE 2018 Update 2. I also include the code and the compilation results attached. Observe that it is possible to point from the module, but it is not possible from the submodule.
!C************************************************************
MODULE parent_module
IMPLICIT NONE
!> Private, public and public protected variables
REAL(8),DIMENSION(5),PROTECTED,TARGET::fi
REAL(8),POINTER,DIMENSION(:),PRIVATE::pfisub=>null(),pfimod=>null()
!> Submodule subroutine interface
INTERFACE
    MODULE SUBROUTINE modifSub
    END SUBROUTINE modifSub
END INTERFACE
CONTAINS
SUBROUTINE modif
    pfimod=>fi(1:3)
END MODULE parent_module
SUBMODULE (parent_module) submod1
IMPLICIT NONE
CONTAINS
    pfisub=>fi(1:3)
END SUBMODULE submod1
FortranFan
Looks like a compiler bug, submit at OSC.  It's yet another in connection with SUBMODULEs and entities of PROTECTED attribute with HOST association.
Intel fixed the 2 cases (one of which was yours) but their feature validation test suite likely has a gap when it comes to POINTER attribute:
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/747601
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/610969
https://software.intel.com/en-us/forums/intel-fortran-compiler-for-linux-and-mac-os-x/topic/713413
Hope Intel team is reading this and will do more than treat this as a bug report, rather do a review of their validation cases and look to catch issues before customers encounter them.
Daniel_Dopico
Thank you fan.
It seems that, at least concerning submodules, Intel Fortran is far from supporting them properly.
This is a bit discouraging because the Fortran standard is quite clear about the rules.
