Inconsistent linking IFPORT
DavidWhite
Valued Contributor II
I am using the same copy of a file in two projects. It has the line
USE ifport, only : SYSTEM, GETLOG, GETENV, GETFILEINFOQQ, DELFILESQQ
One project compiles successfully, the other gives unresolved references on GETLOG and GETENV.
What settings could prevent the linker finding IFPORT?
David
The other setting to look at is Fortran > Compatibility > Use Powerstation Compatibility Library. This is set to Yes by default.
Anonymous66
One setting to check is Properties > Libraries > "Disable Default Library Search Rules." It should be set to "No"
Annalee
DavidWhite
Annalee,
I had already checked that one, and both projects are set to "No".
If I add libifport.lib expliitly to my solution, the project compiles correctly.
Thanks, David
