29578 Discussions
Incorrect error message about a "dotted string" - structure component instead of defined operator
Arjen_Markus
The minimal program below causes the compiler to complain about a structure component instead of the defined operator that is meant. Surrounding the expression with parentheses changes the message.
! triple_min.f90 --
!     Minimal example of the parsing problem
program triple_min
    implicit none
    real :: x
    ! Error message: structure component?
    write(*,*) x .clamp. [0.0, 2.0]
    ! Error message: there is no defined operator (or structure component)
    write(*,*) (x .clamp. [0.0, 2.0])
end program triple_min
Other compilers complain about .clamp. being unknown. The original, full, code that led to this can be found at https://fortran-lang.discourse.group/t/standard-use-of-user-defined-operators/10736/6
Steve_Lionel
The DEC-heritage compiler have had many parsing problems over the years related to the VAX FORTRAN STRUCTURE/RECORD extension of the mid-1980s that used dots as the component separator, whereas Fortran 90 eventually settled on percent. This has led to ambiguities with operators and the compiler has rules where it tries to figure out what you meant, but we had to fix many problems where it got it wrong. I haven't seen one of these for quite a while.
Arjen_Markus
Here is the output of ifx and gfortran on this program:
ifx -c triple_min.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.0.0 Build 20241008
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
triple_min.f90(14): error #6866: Dotted string is neither a defined operator nor a structure component.   [CLAMP]
triple_min.f90(11): error #6535: This variable or component must be of a derived or structure type.   [X]
compilation aborted for triple_min.f90 (code 1)
gfortran -c triple_min.f90
triple_min.f90:11:24:
   11 |     write(*,*) x .clamp. [0.0, 2.0]
      |                        1
Error: Unknown operator 'clamp' at (1)
triple_min.f90:14:25:
   14 |     write(*,*) (x .clamp. [0.0, 2.0])
      |                         1
I have not found an option that instructs ifx not to look for such legacy structure syntax.
andrew_4619
Hmmm, there is clearly a problem but the post here is a little confusing given the sample code is invalid (incomplete) and IFX gives a sane message #6866. The code on the discourse group  where the operator .camp. is actually defined show a compiler error as IFX misinterprets what is IMO valid code and then gives a spurious error message.
! triple.f90 --
!     Is it possible to write an expression like:
!         x = y .clip. [min,max]
!     with .clip. a user-defined operator?
module triple
    implicit none
    public :: operator(.clip.)
    interface operator(.clip.)
        module procedure clip_between
    end interface
contains
real function clip_between( x, range )
    real, intent(in) :: x
    real, intent(in) :: range(2)
    clip_between = max( min( x, range(2)), range(1) )
end function clip_between
end module triple
program test_triple
    use triple
    real :: x
    x = 1.0
    write(*,*) x .clip. [0.0, 2.0]
    write(*,*) x .clip. [0.0, 0.5]
end program test_triple
Arjen_Markus
My apologies for the confusion it caused. I thought to send in a minimal example to show just the error message, but clearly my minimal example is, well, too minimal.
Steve_Lionel
