Incorrect indentation
Nikitopoulos__Theodo
I noticed the following indentation:
    size: if ( nvals <= max_size ) then
        in: do i = 1, 10
        ! get values
    end do in
    else size
    end if size
The "end do" part is not placed correct. Can you check?
Kevin_D_Intel
Yes, I can reproduce this with PSXE 2017 and VS2015. I expect it happens with other combinations too. It occurs with DO appearing inside or outside any additional nesting. I reported this to our integration Developers. Thank you.
(Internal tracking id: DPD200417498)
Hi Kevin,
did you get a tracking number?
Theo
Kevin_D_Intel
My apologies. I thought I noted it earlier. It is now noted above.
