Using latest IVF 8.0.047, I get a incorrect name mangling of _INDC@16 for the integer function "indc" which contains 2 character and one integer argument.
Compiling without "cvf" works ok. Mixed_string_length makes no difference. I already reported this to support. Ian.
! ifort console.f90 works ok
! ifort /iface:cvf console.f90 does not work
program Console1 implicit none integer :: indc,i character(len=4) :: cva(4), cvcva(:)=(/'abcd','efgh',' ',' '/)
cv='efgh'
i=indc(cva,4,cv)
! with /iface:cvf comipler generates _INDC@16 (should be @20) end program Console1!***********************************************************************
integer function indc(cary,nary,cval) implicit none integer :: nary,i character(len=*) :: cary(*),cvalindc=0
do i=1,nary if(cval.eq.cary(i)) thenindc=i
exit endif enddo return end function indc!***********************************************************************
FWIW, it works fine with my 8.0.044 (next-to-last):
/nologo /Zi /Od /iface:cvf /iface:mixed_str_len_arg /module:"Debug/" /object:"Debug/"
/traceback /check:bounds /libs:static /dbglibs /c
(it alsobuilds without /iface:mixed_str_len_arg)
Jugoslav
Please enter a problem report for this.
This is a perfect example to use in the report; the more simple the example, the easier it is for us to work on!
Thank you -
Lorri
