29252 Discussions
Indenting existing free form file
cacciatore
I transformed some old fixed form source files to free form using John Burkardt Fixcon program. As I used TAB to indentsome lines ( not a 'whise' choice according to Mr Burkardt ), the resulting free form file is ugly indented.
I tryied other transforming programs but Fixcon gave best results and is easyer to use.
Does anyone knows of a programthatdoes a niceindent on existing free form source files ?
As forDelphi there is a source formatting tool (DelForExp),I hope there is also one for Fortran.
Thanks for any help.
Geraldo
Jugoslav_Dujic
Valued Contributor II
Why don't you just remove tabs from the originals and redo the conversion? There's an option Edit/Advanced/Untabify selection in VS (or somewhere near) -- just repeat it for all original files and you'll get tab-free files to start with.
cacciatore
Hi Jugoslav,
After posting my message I did what you are just suggesting. The result was better looking, but the real culprit was myoriginal fixed formbad indenting. I had to reindent everything again. In Dev Studio there is a 'Smart Indent' in Tools/Options/Tabs but its options are always grayed. Also always grayed is Edit/Advanced/Format Selection , wich sohuld work with 'smart indent'. So I am still looking for this 'make a nice indenting on my poor looking source' program.
Thanks for answering
Geraldo
Jugoslav_Dujic
Did you try Michael Metcalf's converter? I didn't try it myself, but it's often recomended on comp.lang.fortran?
Jugoslav_Dujic
...or Alan Miller's to_f90.
cacciatore
Hi
I have alreadylooked at f2f90 wich is a modified vertion of Michael Metcalf's convert program. f2f90 does not admits tabsand as atthat time I didn't know of the untabfy command I gave up with f2f90, but will try it again as it says it indents DO loops and IF blocks.I just downloaded 'to_f90' and it seems to have many pitfalls like "May do the wrong thing if variable names start with IF or end with DO", and "DO .. END DO (i.e. no label) or in-line comments may cause havoc!", and others.
Thanks again
Geraldo
