29657 Discussions
Initialize derived type as parameter
Olsen__Oystein
Initializing a derived type as parameter fails if there is an assignment operator. This happens with latest FORTRAN compiler on openSUSE 11.4. The following code demonstrates the problem:
[fortran]MODULE DType
  IMPLICIT NONE
  PUBLIC
  INTEGER, PARAMETER :: I4B = SELECTED_INT_KIND(9)
  !INTEGER, PARAMETER  :: QP = SELECTED_REAL_KIND(6,37)
  !INTEGER, PARAMETER  :: QP = SELECTED_REAL_KIND(15,307)
  INTEGER, PARAMETER  :: QP = SELECTED_REAL_KIND(32,4931)
  TYPE JD
     INTEGER(I4B) :: JDN = 2451545
     REAL(QP)     :: FD = 0.0_QP
   CONTAINS
     GENERIC                  :: ASSIGNMENT(=) => setJD
     PROCEDURE, PRIVATE, PASS :: setJD
  END TYPE JD
CONTAINS
  SUBROUTINE setJD(a, b)
    CLASS(JD), INTENT(INOUT) :: a
    TYPE(JD), INTENT(IN)     :: b
    a%JDN = b%JDN
    a%FD = b%FD
  END SUBROUTINE setJD
END MODULE DType
PROGRAM test_dtype
  USE DType
  IMPLICIT NONE
  TYPE(JD), PARAMETER :: testa = JD(2451546, 0.5_QP)
  TYPE(JD) :: testb = JD(2451546, 0.5_QP)
  WRITE(*,*) testa%JDN, testa%FD
  WRITE(*,*) testb%JDN, testb%FD
END PROGRAM test_dtype[/fortran]
The first write statement returns
1 1.0000000
instead of
2451546 0.50000000
Thanks for the nice test case. I can reproduce the problem and verified that it is the presence of the type-bound operator that makes the difference, even though that operator is not used. I have escalated this as issue DPD200170709 and will let you know of any progress.
This is fixed for a release later this year.
