29657 Discussions
Input/Output Error 178: Interrupted system call
Intel_C_Intel
I've recently started experiencing problems when using the -pg option when compiling a fortran code with ifc 7.1. The code occasionally crashes with an error message such as:
In Procedure: main program
At Line: 168
Statement: OPEN
Unit: 49
Connected To: /home/dj/model.100/progression
The crash always seems to occur at an "open" statement, but not always the same one. Without the -pg option I have no problems (and until about 1 week ago -pg always worked just fine for me!).
Does anyone have any clue what might be going on here?
Andrew
Intel_C_Intel
It turns out that the problem was due to an anti-virus package (AvGuard) that I had running. This scans files for viruses as they're opened and, for some reason, seems to cause a conflict with the -pg option.
However, I'm now experiencing crashes with the error:
** FPE Signal **
. This seems only to occur when I make use of the Math Kernel Library routines along with the -pg option......
