29487 Discussions
Input data file with columns divided in blocks
Paulo_M_
Hello all,
I need to read a 62x14 table which is generated by an external program. However the external program splits the table in two parts, showing the first 10 columns and the remaining columns just below the first part. Is it possible to read such table in my Fortran code? What should be done?
Paulo
mecej4
Assuming that the data files contains one block with 62 rows and 10 columns, and a subsequent block with 62 rows and four columns:
program tblread
implicit none
integer, parameter :: NROWS=62,NCOLS=14,NSPLT=10
real, dimension(NROWS,NCOLS) :: tbl
integer :: i,j
open(unit=11,file='...')
read(11,*)((tbl(i,j),j=1,NSPLT),i=1,NROWS)
read(11,*)((tbl(i,j),j=NSPLT+1,NCOLS),i=1,NROWS)
end program
