Inquiring a module at runtime
rahzan
Is there a way to tell if a certain routine exists in a module at run time?
Tim
Jugoslav_Dujic
Valued Contributor II
A module? How can you even compile the code with a missing module?
If you mean a DLL, you could query its existence using LoadLibrary and then use GetProcAddress to reach its address and call it. See LOADEXP1 CVF sample or search this Forum for GetProcAddress.
Jugoslav
rahzan
Yes I meant a module in a DLL.
Thanks for the lead on the sample,
I just found it myself too.
Tim
