29433 Discussions
Inspect variable declared in the specification part of a module
Luis_Solis
In the example below
module foo
integer, dimension(:),allocatable:: im
integer, parameter:: n=3
contains
subroutine s1(i)
integer:: i
allocate(im(2))
im=i
write(*,*) im
end subroutine
end module
program main
use foo
i=1
call s1(i)
end program
If I put a breakpoint in write(*,*)
The array a or the parameter n are undefined in locals and watch windows
Is there a way to inspect the contents of the a or n
Best regards
I don't see an array a in this code. There is an array im. If the variable is not used in the current scope, you can use the syntax modname::varname in a Watch window to view it.
n is a PARAMETER constant and is not visible by default. There is a compiler option /debug-parameters that controls visibility.
