29487 Discussions
Install/Un-install issues with Intel Visual Fortran Composer XE 2011
Ashish_R_
I successfully installed the Intel Visual Fortran Composer on Windows 7.
The integration with Visual Studio 2005, 2008 and 2010 are working correctly.
I have changed my mind and now I want to uninstall the same and go back to version 10.1.029.
After I un-install from Control Panel/Program/Program and Features/Uninstall, I can still see the integration with Visual Studio remains as before. And I can still see the options for creating a new project with Intel Visual Fortran.
How can I get back to the state where I do not see ant Intel VisualFortran Composer?
Looks like, theun-install process is notclean.
Uninstall. Delete the "Intel Fortran" folder under your VS directories. Install the old version.
The problem seems to revolve around "reference counts" in the registry.
Nikolay_L_Intel
Thank you for you feedback. This is known problem, it will be fixed in next major version.
Steve is correct. This workaround should help. Thank you,
- Nikolay
