Install parallel_studio_xe_2016_composer_edition failed (linux)
Marcos_C_
Hello
I'm trying to install it, but I have the next problem at the end of installation.
Step 6 of 7 | Installation
Each component will be installed individually. If you cancel the installation,
some components might remain on your system. This installation may take several
minutes, depending on your system and the options you selected.
Installing Intel(R) MPI Library, Runtime Environment for applications running on
Intel(R) 64 Architecture component... done
Intel(R) Many Integrated Core Architecture component... done
Installing Intel C++ Compiler for Intel(R) 64 component... done
Installing Intel Fortran Compiler for Intel(R) 64 component... done
Installing Intel MKL core libraries for Intel(R) 64 component... done
Installing Intel(R) Xeon Phi(TM) coprocessor support component... done
Installing Fortran 95 interfaces for BLAS and LAPACK for Intel(R) 64
component... done
Installing GNU* Compiler Collection support for Intel(R) 64 component... done
Installing Cluster support for Intel(R) 64 component... done
Installing Intel IPP single-threaded libraries for Intel(R) 64: General package
component... done
Installing Intel TBB component... done
Installing Intel DAAL for Intel(R) 64 component... done
Installing GNU* GDB 7.6 (Provided under GNU General Public License v3)
component... done
Installing libelfdwarf.so library and it's sources (Provided under GNU Lesser
General Public License) component... done
Installing GDB Eclipse* Integration on Intel(R) 64 (Provided under Eclipse
Public License v.1.0) component... done
Installing Source of GDB Eclipse* Integration (Provided under Eclipse Public
Installing GNU* GDB 7.8 on Intel(R) 64 (Provided under GNU General Public
License v3) component... done
Finalizing product configuration...
Unable to initialize transfer functionality, exiting...
I have made a clean installation using the uninstall.sh files but I still have the same problem. I also have attached the both log files.
Thanks!
P.d: I've installed the CURL library, but still doesn't work with the same error.
Kevin_D_Intel
We apologize for the installation failure. It appears the installation of the product is complete and it should be usable. What appears to be failing is final notification back to the Intel Registration Center regarding the successful installation.
I reported the failure to our Installation Development team and will let know what I hear back regarding their investigation of the error.
If you want to move forward using the new release then you could redo the installation and ignore the error in the end. Once it is re-installed try initializing your environment using the psxevars.sh/csh and then try using the compiler and other tools.
(Internal tracking id: DPD200376724)
(Resolution Update on 11/20/2015): This defect is fixed in the Intel® Parallel Studio XE 2016 Update 1 Release (PSXE 2016.1.056 - Linux)
mecej4
On OpenSuse 13.2, I had a similar failure when I ran the character-mode installer. I then ran the GUI installer and that worked fine, but there seemed to be no way to specify a non-default install location, as a result of which the /opt slice became 75 percent full. One of these days, I'll have to run the GUI installer again, more carefully.
Kevin_D_Intel
Thank you for the insight mecej4. I pass that on to the Developers.
The behavior regarding a non-default directory sounds like a possible defect that I’ll have to try replicating.
Kevin_D_Intel
The installation error "Unable to initialize..." reported in the original post is fixed in our upcoming Parallel Studio XE 2016 Update 1 due to release later this week or early next.
