29273 Discussions
Installation ERROR: unable to find command "g++"
sebyan
I've just downloaded the Fortran compiler 10.1.015. When I install it to openSUSE 10.2, after the commond "./install.sh", I get a warning as below:
ERROR: unable to find command "g++" !
It appears that one of the missing commands is the 'g++' command.
Some Linux distributions do not include 'g++' as a part of the 'gcc' installation.
Please locate and install the proper 'g++' package for your system and restart the installation process for this Intel software product.
Please add the location to the above commands to your PATH and re-run the script.
Please press Enter to continue...
Anyone could tell me how to solve this problem? Thanks!
seb
TimP
Open up your software installation menu, enter root password, plug in SuSE installation DVD or otherwise connect your install media. Search for g++ . If this is a 64-bit OS, select 32-bit as well as 64-bit compilers. Accept the installation.
sebyan
Thank you Tim. I actually installed SuSE from harddrive and don't have the DVD diver. I've searched g++ in the software management but can't find anything like gcc or g++. Do you have any idea where I can obtain it? Thanks a lot.
sphost
Use Yast to download and install it from internet.
sebyan
Thanks a lot. I've installed them by searching gcc in YaST. The compiler is installed as well.
leilasalimi
Quoting - sebyan
I have the same problem , but I don underestand how you solve your problem .
Can you tell me more about that ?
Best Regards
leilasalimi
Quoting - leilasalimi
Best Regards
I use Fedora10 , want to instal Ifort10 in my system, but I see the same problem.
TimP
You should be able to install g++ development system from your Fedora install CD, or by yum update.
