Hi, I'm trying to install Intel's Fortran Composer XE 2011 on a 32-bit ubuntu system. When I try to run the install.sh script I get the following message:
"trap: 279: SIGTSTP: bad trap"
I've tried once again after deleting the 279-line, and I get now the following message:
"Error: Incorrect path to installation script. Installation can not be started
if the path contains space symbols.
Quitting! Press "Enter" to terminate install.
read: 288: arg count
exit: 288: Illegal number: -1"
Nevertheless, the path to installation script has no space symbols! It reads: /home/username/fortranide/fortran2003/
Can anybody help me?
Thanks in advance.
Thanks in advance.
This is news to me. First, what version of Ubuntu are you using? And what is the file name for the installation package for Composer XE? l_fcompxe_ia32_2011.0.084.tgz correct?
And did you read the guide to setting up Ubuntu to use the Intel compilers:
http://software.intel.com/en-us/articles/using-intel-compilers-for-linux-with-ubuntu/
ron
Thanks for your answer!
I use v. 10.04. I've checked the guide and I have already installed gcc (v.4.4.3), build-essential, rpm and JRE 6. The file was named l_fcompxe_2011.0.084.tgz.
I'll look for l_fcompxe_ia32_2011.0.084.tgz.
I just had a similar problem
try running
sudo ./install.sh , instead of sudo sh ./install.sh
Thanks, folk! This was the point.
