29333 Discussions
Installation problems with Visual Studio 2017 15.4.1 and Intel PSXE 18.0
Sean_B_1
Okay, it seems like the problem was that Parallel Studio XE 2013 was installed.  I uninstalled Visual Studio 2010 and PSXE 2013 and everything is working fine now.  Is this expected behavior?
Steve_Lionel
No, it isn't expected. But the process for installing the integration is complex and sometimes it doesn't quite go right. I'm a bit puzzled that a PSXE 2013 install would interfere with integration of PSXE2018 into VS2017, since PSXE2013 knows nothing about VS2017, but...
In the past I would recommend uninstalling PSXE, deleting the "Intel Fortran" folder from under the Visual Studio folder, then reinstalling. That almost always worked. But VS2017 uses a different integration method and there is no "Intel Fortran" folder.
