29487 Discussions
Integer value out-of-range: why warning in an initialization expression but not in an assignment?
FortranFan
Consider the following simple code:
   use, intrinsic :: iso_fortran_env, only : IK => int8
   integer(kind=IK) :: foo
   foo = int( 256, kind=kind(foo) )
end
Intel Fortran compiler gives no warnings with above code:
xx>ifort /c /standard-semantics /warn:all /stand p.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R
) 64, Version 18.0.0.124 Build 20170811
Copyright (C) 1985-2017 Intel Corporation.  All rights reserved.
xx>
Now consider the following where an initialization expression is used:
   integer(kind=IK) :: foo = int( 256, kind=kind(foo) )
end
The compiler then issues a warning, #6047:
p.f90(3): warning #6047: The BYTE / LOGICAL(KIND=1) / INTEGER(KIND=1) value is out-of-range.
Can someone from the Intel Fortran team please explain why the warning in the second case and not in the first?
Steve_Lionel
I can tell you - the Fortran-specific "front end", that processes compile-time arithmetic, can catch overflows in many cases . But the multi-language code generator has no support for run-time integer overflow detection. It has been on the "wish list" for many years, but never implemented by the code generator developers.
It's not clear to me if this specific case could be detected by the front-end. Maybe. But the general case of run-time integer overflow detection is not available.
mecej4
Sometimes, the situation is as if the compiler and the runtime are running on different processors. Years ago, I ran into the following problem. A program used 1D70 as a guard value, to represent infinity or "not yet set". Variables were set to this value using a DATA statement, and the same value was used with the same meaning in formatted input data.
      PROGRAM REALBUG
      DOUBLE PRECISION SIGMA,BND
      DATA SIGMA /1.0D70/
      READ (*,*) BND
      write(*,10)BND,SIGMA,BND.GT.SIGMA
   10 format(1x,1p,D24.17,' > ',D24.17,' ?  ',L5)
      END
When the program was run, and the input was "1.0D70", the output was
  1.00000000000000000D+70 >  1.00000000000000000D+70 ?      T
The decimal to IEEE conversion in the compiler and the similar conversion routine of the RTL I/O routines produced a difference in the least significant bit of the mantissa, and the comparison gave an unexpected answer.
This problem occurred with a compiler from a different vendor than Intel.
Steve_Lionel
I've seen the "different results from compile-time and run-time" evaluation often. If you identify such issues, do report them.
