Intel 14 and 15 compiler bug
Neil_Carlson
I've attached a very small example that exposes a bug in 14.0.3 and 15.0.2.  In the example, a module declares a derived type and a F2003 structure constructor for it.  In a later procedure the module is USEd and the type referenced, but the compiler complains incorrectly that the type is not known.  The error goes away if the structure constructor is not defined.
Escalated as issue DPD200371229. The error also goes away, oddly enough, if you remove the call to "bar" from the subroutine. Thanks for the nice example.
I'm told this will be fixed for the 16.0 release.
