29657 Discussions
Intel Array visualizer & intel Composer XE 2011 in debug mode
Sebastien_D_
Hi, I would like to know if it's possible to use intel array visualizer with intel composer XE 2011 in debug mode. I already read a few post on this forum about this problem and i have learned that Intel Visual fortran must be install after iAV. I aslo try it but it doesn't work. It seems a repair tool exist to fix this problem, but I can't find it. Any idea ?
For information, my configuration is :
  • Windows seven 64bits
  • intel Array Visualizer 3.3 (installed with "av_dev_ia32")
  • intel Composer XE 2011
I also check if iAV was well installed with this tutorial : http://software.intel.com/en-us/forums/topic/296940 and it works fine.
Any idea to help me ? ;)
tropfen
Hello Sebastien, the short answer is: The Array Viewer is not working on 64bit systems. One possible solution is: If you have at least Win7 Prof the you can use the WinXP Mode. Install IVF and AV in the XPMode and it will work there. Frank
Sebastien_D_
Hello tropfen, thank you for your advice, i'll try it ;)
