Compiler Bug ?
Dietmar_P_
Hi
Have compiled the following program once as debug version (OK) and once as a Release Version (faulty) and get different results for the two dot products computed. Should give the same results.
Compiling with Intel(R) Visual Fortran Compiler XE 12.1.2.278 [Intel(R) 64]...
ifort /nologo /Os /module:"x64\Release\\" /object:"x64\Release\\" /Fd"x64\Release\vc100.pdb" /libs:static /threads /c /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin\amd64" "D:\Work\test_speed\problem_destilled.f90"
Linking...
Link /OUT:"x64\Release\test_speed.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"D:\Work\test_speed\test_speed\x64\Release\test_speed.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /SUBSYSTEM:CONSOLE /IMPLIB:"D:\Work\test_speed\test_speed\x64\Release\test_speed.lib" "x64\Release\problem_destilled.obj"
Link: executing 'link'
Embedding manifest...
mt.exe /nologo /outputresource:"D:\Work\test_speed\test_speed\x64\Release\test_speed.exe;#1" /manifest "D:\Work\test_speed\test_speed\x64\Release\test_speed.exe.intermediate.manifest"
Program:
program problem_destilled
  implicit none
  integer, parameter :: MAX_NUMBER_STORAGE = 100000000
  integer, parameter :: MAX_BLOCK_SIZE = 8*1024*1024
  integer, parameter :: BLOCK_SIZE_I = MAX_BLOCK_SIZE/4
  integer, parameter :: BLOCK_SIZE_R = MAX_BLOCK_SIZE/4
  integer, parameter :: NUM_REP = 100
  integer :: idxRep, idxBlock, idx, index
  integer :: numBlocks, remainder
  real, allocatable, dimension(:) :: vec1, vec2
  real :: dot1(NUM_REP), dot2(NUM_REP)
  real :: time, duration1, duration2, duration3
  allocate( vec1(MAX_NUMBER_STORAGE) )
  allocate( vec2(MAX_NUMBER_STORAGE) )
  vec1 = 0.0
  vec2 = 0.0
  do idxRep = 1, NUM_REP
     vec1(idxRep) = 1.0
     vec2(idxRep) = 1.0
     dot1(idxRep) = 0.0
     do idx = 1, MAX_NUMBER_STORAGE
        dot1(idxRep) = dot1(idxRep) + vec1(idx)*vec2(idx)
     end do
  end do
  vec1(1:NUM_REP) = 0.0
  vec2(1:NUM_REP) = 0.0
     vec1(idxRep) = 1.0
     vec2(idxRep) = 1.0
     dot2(idxRep) = 0.0
     numBlocks = MAX_NUMBER_STORAGE/BLOCK_SIZE_R
     remainder = mod( MAX_NUMBER_STORAGE, BLOCK_SIZE_R )
!     print*, BLOCK_SIZE_R, numBlocks, remainder
     do idxBlock = 0, numBlocks-1
        do idx = 1, BLOCK_SIZE_R
           index = idxBlock*BLOCK_SIZE_R + idx
           dot2(idxRep) = dot2(idxRep) + vec1(index)*vec2(index)
        end do
     end do
     do idx = 1, remainder
        index = numBlocks*BLOCK_SIZE_R + idx
     end do
  end do
     print*, idxRep, dot1(idxRep), dot2(idxRep)
  end do
  deallocate( vec1 )
  deallocate( vec2 )
end program problem_destilled
The content of dot1 and dot2 should be:
1.0 2.0 3.0 ... 100.0 but in this case dot2 is zero in all its components.
Can this be reproduced/explained?
Cheers
Dietmar
Ron_Green
We'll investigate this, test with latest compilers, etc. and report back shortly. ron
Ron_Green
I believe the bug is with the /Os option. Try this Project -> Properties -> Fortran -> Optimization property page on this Optimization Properties, set "Favor Size or Speed" to "Favor Fast Code" For me, that worked around the bug. There is a bug with /Os and your code. I'll write it up. ron
Ron_Green
No, it looks like anything at O2 or Os is affected. Bug ID is DPD200179556. It is related to loop distribution optimization. ron
