Intel Compiler **Internal compiler error: internal abort** related to coarray and transpose
northrup
I have run into an issue trying to use coarrays with transpose causing the Intel fortran compiler to crash.
Its on centos 6.4 with compiler version
$ ifort --version
ifort (IFORT) 14.0.1 20131008
$ ifort testfft.short.f90 -coarray=shared -o mytest
testfft.short.f90(29): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for testfft.short.f90 (code 1)
The sample code is
[fortran]
integer, parameter :: ngrid=4,ncube=2
real, dimension(ngrid/ncube*ncube,ngrid/ncube,ncube,ngrid/ncube,ncube) :: rho3[ncube,ncube,*]
complex, dimension(ngrid*ncube/2+1,ngrid/ncube,ncube,ngrid/ncube) :: crhox[ncube,ncube,*]
complex, dimension(ngrid/ncube,ncube,ncube,ngrid/ncube,ngrid/2+1) :: crhoy[ncube,ncube,*]
complex, dimension(ngrid/ncube,ncube,ncube,ngrid/2+1,ngrid/ncube) :: crhoz[ncube,ncube,*]
integer mycoord(3)
mycoord=this_image(rho3)
! align x-axis first
ic=mycoord(2)
iy=mycoord(1)
iz=mycoord(3)
! now transpose x-y
sync all
ix=mycoord(3)
ixlen=ngrid/2
do ib=1,ncube
   do iy=1,ncube
      do k=1,ngrid/ncube
         imin=(ix-1)*ngrid/2+1
         imax=imin+ixlen-1
         crhoy(:,ib,iy,k,:ixlen)=transpose(crhox(imin:imax,:,ib,k)[iy,mycoord(1),mycoord(2)])
      end do
   end do
end do
end program
[/fortran]
northrup
We found another case causing a similiar compiler abort, but this time by just turning the -debug or -g flags.  The odd thing is it works fine without them, ie the default optimization level seems to compile the code and it runs as expected.
$ ifort -fpp -debug all -coarray  testfftopt.f90
010101_0
compilation aborted for testfftopt.f90 (code 1)
$ifort -fpp -coarray  testfftopt.f90
but works fine.  Same setup as the previous case, ifort (IFORT) 14.0.1 20131008, it also seems to cause a crash on v13.1 of the compiler as well.
I have attached the code.
Steven_L_Intel1
Thanks - we'll take a look.
Steven_L_Intel1
This is already fixed for update 2, due out in early February. For reference, our issue ID is DPD200247083. The bug relates to asking for debug information in when a contained routine contained coarray references.
northrup
Steve,
Thanks for the update.   Does the fix deal with the transpose and coarray issue shown in the first post example as well?
Steven_L_Intel1
Sorry, no. I had overlooked that you were reporting two different problems. The TRANSPOSE problem is still there and I will report it to the developers. Issue ID is DPD200252838.
Steven_L_Intel1
The TRANSPOSE problem has been fixed and I expect the fix to be included in Update 3 (late April).
