29386 Discussions
Intel Compiler **Internal compiler error: internal abort** related to coarray and transpose
northrup
I have run into an issue trying to use coarrays with transpose causing the Intel fortran compiler to crash.
Its on centos 6.4 with compiler version
$ ifort --version
ifort (IFORT) 14.0.1 20131008
$ ifort testfft.short.f90 -coarray=shared -o mytest
testfft.short.f90(29): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for testfft.short.f90 (code 1)
The sample code is
[fortran]
integer, parameter :: ngrid=4,ncube=2
real, dimension(ngrid/ncube*ncube,ngrid/ncube,ncube,ngrid/ncube,ncube) :: rho3[ncube,ncube,*]
complex, dimension(ngrid*ncube/2+1,ngrid/ncube,ncube,ngrid/ncube) :: crhox[ncube,ncube,*]
complex, dimension(ngrid/ncube,ncube,ncube,ngrid/ncube,ngrid/2+1) :: crhoy[ncube,ncube,*]
complex, dimension(ngrid/ncube,ncube,ncube,ngrid/2+1,ngrid/ncube) :: crhoz[ncube,ncube,*]
integer mycoord(3)
mycoord=this_image(rho3)
! align x-axis first
ic=mycoord(2)
iy=mycoord(1)
iz=mycoord(3)
! now transpose x-y
sync all
ix=mycoord(3)
ixlen=ngrid/2
do ib=1,ncube
   do iy=1,ncube
      do k=1,ngrid/ncube
         imin=(ix-1)*ngrid/2+1
         imax=imin+ixlen-1
         crhoy(:,ib,iy,k,:ixlen)=transpose(crhox(imin:imax,:,ib,k)[iy,mycoord(1),mycoord(2)])
      end do
   end do
end do
end program
[/fortran]
northrup
We found another case causing a similiar compiler abort, but this time by just turning the -debug or -g flags.  The odd thing is it works fine without them, ie the default optimization level seems to compile the code and it runs as expected.
$ ifort -fpp -debug all -coarray  testfftopt.f90
010101_0
compilation aborted for testfftopt.f90 (code 1)
$ifort -fpp -coarray  testfftopt.f90
but works fine.  Same setup as the previous case, ifort (IFORT) 14.0.1 20131008, it also seems to cause a crash on v13.1 of the compiler as well.
I have attached the code.
Thanks - we'll take a look.
This is already fixed for update 2, due out in early February. For reference, our issue ID is DPD200247083. The bug relates to asking for debug information in when a contained routine contained coarray references.
northrup
Steve,
Thanks for the update.   Does the fix deal with the transpose and coarray issue shown in the first post example as well?
Sorry, no. I had overlooked that you were reporting two different problems. The TRANSPOSE problem is still there and I will report it to the developers. Issue ID is DPD200252838.
The TRANSPOSE problem has been fixed and I expect the fix to be included in Update 3 (late April).
