29435 Discussions
Intel Composer stumbles over overlay
jr_reuter
The following code is not correctly compiled by the Intel Fortran Compiler with the following version:
Intel Fortran Compiler XE for applications running on IA-32, Version 12.0.1.107 Build 20101116
The error message is the following:
processes.f90(94): error #7096: The type/rank/keyword signature for this specific procedure matches another specific procedure that shares the same generic-spec. [STRFUN^BEAMS^BEAM_ASSIGN]
use strfun
processes.f90(93): error #7096: The type/rank/keyword signature for this specific procedure matches another specific procedure that shares the same generic-spec. [BEAMS^BEAM_ASSIGN]
use beams
compilation aborted for processes.f90 (code 1)
Note that all other compilers at my hand do compile the code
(NAG, gfortran, g95, Portland)
Here is the code:
! Putting this in the same module beams makes the bug vanish
module interactions
implicit none
private
public :: interaction_t
type :: interaction_t
private
integer :: tag = 0
end type interaction_t
end module interactions
module beams
use interactions
implicit none
private
public :: beam_t
public :: assignment(=)
type :: beam_t
private
type(interaction_t) :: int
end type beam_t
interface assignment(=)
module procedure beam_assign
end interface
contains
subroutine beam_assign (beam_out, beam_in)
type(beam_t), intent(out) :: beam_out
type(beam_t), intent(in) :: beam_in
beam_out%int = beam_in%int
end subroutine beam_assign
end module beams
module strfun
use beams
implicit none
private
public :: strfun_chain_t
!!! Commenting out this line triggers the error going away!!!
type :: strfun_t
private
integer :: type = 0
end type strfun_t
type :: strfun_chain_t
private
type(beam_t) :: beam
type(strfun_t), dimension(:), allocatable :: strfun
end type strfun_chain_t
!!! THIS PART OF THE CODE IS NOT NEEDED TO REPRODUCE THE BUG
!!! interface assignment(=)
!!! module procedure strfun_chain_assign
!!! end interface
!!!contains
!!! subroutine strfun_chain_assign (sfchain_out, sfchain_in)
!!! type(strfun_chain_t), intent(out) :: sfchain_out
!!! type(strfun_chain_t), intent(in) :: sfchain_in
!!! sfchain_out%beam = sfchain_in%beam
!!! end subroutine strfun_chain_assign
end module strfun
module processes
use beams
use strfun
implicit none
private
!!! Commenting out these lines triggers the error going away!!!
type :: md5sum_grids_t
character(32) :: beams = ""
end type md5sum_grids_t
end module processes
Kevin_D_Intel
Thank you for notifying us about this. I reproduced the errors andwill submit to Develpment and update this post as I learn more.
(Internal tracking id: DPD200164645)
(Resolution Update on 05/17/2011): This defect is fixed in the Intel Fortran Composer XE 2011 Update 4 (2011.4.191 - Linux)
jr_reuter
So how long does it normally take to assign such a bug and fix it for the Intel Compiler?
From gfortran and NAG that is usually order of days, for Portland it is order a few weeks. For Intel I reported
this error (actually tried to report this error) during the several updates of the 11.0 and 11.1 compilers
for more than a year now (more like one and a half years). And now the post on the Forum is also
already 3 weeks old. Just to be curious...
mecej4
You can see for yourself by browsing the compiler forums.
My observations:
i) workarounds, if possible, are posted anywhere from within a few hours to a few days.
ii) most bugs are fixed and the bug-fixes are rolled into the next update; updates come out at two to three month intervals.
iii) some bugs are troublesome in that changing the compiler to fix those bugs would break other parts of the compiler; some other bugs are just hard to fix; then there are bugs that may disappear on their own when a major revision of the compiler is made. The bugs in these categories take anywhere from two or three updates to the next major release.
Kevin_D_Intel
My apologies for the delay. Typically, reproducing and reporting to Development usually is just a matter of a day or two. There were extenuating circumstances that delayed my getting that done for this case and a couple of others. I am catching up on them now.
Providing a fix is gated by the time Developers require to investigate, fix and test, and then availability is further based on release schedules. We provide updates on availability of a fix and any work-around as we learn them.
As for this error, I do not have information about what you may have reported earlier, but the issue does not exist with 11.1 Build 20101201 (Package ID: l_cprof_p_11.1.075). The code compiles as written. You also already noted a possible work-around of including module interactions inside module beam, which I confirmed works with the XE 2011 release.
This has been sent to Development. I noted the internal tracking id in my earlier post and will post updates as I learn more.
jr_reuter
Ok, you are going to an older version of the compiler now. I have made the experience that this error is there
and was always there. Just when the compiler version was updated the error moved to a different part of the code. What I could do (and I offered that several times) to send you our complete code (which is however roughly 50,000 to 60,000 lines of Fortran code and check with the different compiler versions.
Kevin_D_Intel
Sorry for the delay. I reviewed the history of your Premier issues submittedand found for the last one submitted in the Feb. 2010 that you attached your entire code. I assume that copy is no longer current. I did not see an instance of the error #7096 though.
If you want, please open another Premier issue to provide the current code to me and then I can check it against different compiler versions. You can request the issue be assigned to me. Alternatively, you can upload the gzipped-tar to this forum using a Private reply.
Development has not provided any further update regarding the error #7096 reported here. I will update on that when I learn more.
jr_reuter
Ok, cool. For some reason I cannot open up any new premier support issues (maybe my support has run out, but I don't know. I open up a tarball for you. Let me prepare it and break it down to treatable blocks.
jr_reuter
OMG, in preparing my code, I found out that the newest version 12.0.1 does have another ICE. Will open a separate issue for this.
Kevin_D_Intel
I'm sorry to hear this. Your Premier account is still active so I'm not sure what you faced there. I'll watch for your updates about the tarball.
