29654 Discussions
Intel FORTRAN running on Linux---runtime error
hyv
Running a working code on a Linux machine with Intel's 10.1 FORTRAN compiler, I recieved this error during execussion:
1 Exit code -5 signaled from i171-212.ranger.tacc.utexas.edu
2 Killing remote processes...MPI process terminated unexpectedly
3 DONE
4 forrtl: No such file or directory
Is there a runtime library that may be missing?
Any thoughts on how to address this?
Thank you,
Hezky
Ron_Green
try compiling with -static-intel -heap-arrays
If you have a pbs script that launches your run, make sure the script has a line to 'source /ifortvars.sh' (this for a bash script). Often times the job launcher won't carry the env vars for the child processes.
But the -static-intel should be a big help, it statically links in the Intel Fortran runtime libs.
ron
roddur
Are you running the job straight where there exist a job-schedular? Then there may also be some script that may kill your job after some time.
hyv
Yes, I am running through a job scheduler, and I have as my FORTRAN optimization flag set as:
foptflags = -mcmodel=medium -shared-intel
TimP
Either a limit set by the administrators for the queue, or a limit you are required to specify.
Ron_Green
Looks like your code is not using OpenMP, so add -heap-arrays to your compiler options
