Intel Fortran 11.1 on Lion OS
Reza
I am trying to run my fortran code in my Mac and I get the following error:
Command /Developer/usr/local/bin/ifort-11.1-base/bin/intel64/ifort failed with exit code 1
I just updated my OS to Lion and tried my previous Fortran codes in the Lion and it seems that they are working well except the new code.
I am wondering if you could help me with that.
Steven_L_Intel1
Not supported. Composer XE 2011 Update 5 is the first to support OS X Lion.
Reza
Thanks for your fast reply.
I understand that, but why my old fortran codes is running in Lion not the new one?
Reza
Steven_L_Intel1
Is there another message before "exit 1"? Lion makes incompatible changes in many areas that can cause trouble for the compiler.
Reza
yes, there are two warnings:
ipo:0:0 warning #11015: Warning unknown option -no_compact_unwind
ld:0:0 symbol(s) not found
and then the error message:
