I am trying to run my fortran code in my Mac and I get the following error:
Command /Developer/usr/local/bin/ifort-11.1-base/bin/intel64/ifort failed with exit code 1
I just updated my OS to Lion and tried my previous Fortran codes in the Lion and it seems that they are working well except the new code.
I am wondering if you could help me with that.
Not supported. Composer XE 2011 Update 5 is the first to support OS X Lion.
Thanks for your fast reply.
I understand that, but why my old fortran codes is running in Lion not the new one?Reza
Is there another message before "exit 1"? Lion makes incompatible changes in many areas that can cause trouble for the compiler.
yes, there are two warnings:
ipo:0:0 warning #11015: Warning unknown option -no_compact_unwind
ld:0:0 symbol(s) not found
and then the error message:
