29654 Discussions
Intel Fortran - C# Interoperability
akrallis
Hello ,
We are working on an interoperability project between FORTRAN and C# . The goal is to create a subroutine in DLL form using FORTRAN and then create a managed prototype for this in C# .
The FORTRAN subroutine is a simple program that adds two numbers:
! test_dll.f90
! FUNCTIONS/SUBROUTINES exported from test_dll.dll:
! test_dll - subroutine
subroutine test_dll(a,b,c)
! Expose subroutine test_dll to users of this DLL
!DEC$ ATTRIBUTES DLLEXPORT::test_dll
! Variables
double precision, intent(in) :: a, b
double precision, intent(out) :: c
! Body of test_dll
c = a + b
end subroutine test_dll
And the C# Console Application for this is :
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Runtime.InteropServices;
namespace ConsoleApplication1
class Program
[DllImport("TEST_DLL.dll", CharSet = CharSet.Auto, SetLastError = true)]
public static extern bool TEST_DLL([In] ref double x,
[In] ref double y,
[In, Out] ref double z);
static void Main(string[] args)
double x, y, z;
x = 1.5;
y = 0.5;
z = 0;
TEST_DLL(ref x, ref y, ref z);
Console.WriteLine("{0} + {1} = {2}", x, y, z);
Console.ReadKey();
The above example works without any problems .
But whenwe try to make a call to a function of the IMSL library within the FORTRAN dll then we get a:
System.AccessViolationException error from the C# Console application
The Fortran DLL is:
FORTRAN :
! Dll2.f90
! FUNCTIONS/SUBROUTINES exported from Dll2.dll:
! Dll2 - subroutine
subroutine Dll2 (ido,t1,t2,a,b,c,y)
! Expose subroutine Dll2 to users of this DLL
!DEC$ ATTRIBUTES DLLEXPORT::Dll2
INCLUDE 'link_fnl_static.h'
!DEC$ OBJCOMMENT lib:"libguide.lib"
USE IVPAG_INT
USE MYMOD
IMPLICIT NONE
! Variables
TYPE(param_type) :: parameters
integer(4), intent(inout) :: ido
double precision, intent(inout) :: t1, t2, a, b
double precision, intent(inout) :: c
double precision, dimension (0:1), intent (inout) :: y
integer(4) :: neq
double precision :: tol, da, db, dc
double precision, dimension(50) :: PARAM
double precision, dimension(1,1) :: A1
external FCN, FCNJ
!COMMON/MAIN_FCN/da,db,dc
! Body of Dll2
parameters%k = a
parameters%l = b
neq = 1
tol = 1.d-6
PARAM = 0.d0
PARAM(1)=1.D-10
PARAM(4)=5.D8
PARAM(10)=2
PARAM(12)=2
PARAM(13)=2
c = parameters%k+parameters%l
da = a
db = b
dc = c
call d_ivpag(ido, fcn, fcnj, t1, t2, y, tol=tol, param=param)
end subroutine Dll2
SUBROUTINE FCN(NEQ,X,Y,YPRIME)
IMPLICIT NONE
INTEGER(4) :: NEQ
DOUBLE PRECISION :: da,db,dc,x
DOUBLE PRECISION, DIMENSION(0:1) :: Y, YPRIME
YPRIME(0) = y(0)**2.d0-(3.d0/2.d0)*y(0)
END SUBROUTINE FCN
SUBROUTINE FCNJ(NEQ,X,Y,DYPDY)
IMPLICIT NONE
INTEGER(4) :: NEQ
DOUBLE PRECISION :: X
DOUBLE PRECISION, DIMENSION(0:1,0:1) :: DYPDY
END SUBROUTINE FCNJ
From the debuger we can see that the call d_ivpag works ok but the error occurs in the FCN callback function.
Could this problem be related to the calling convention ? The above example uses the default calling convention.Please note that this example was working in the CVF Fortran.
Any ideas or other help would be highly appriciated .
Thanks in advance .
Steven_L_Intel1
First, please double-check something. You say that "the above example uses the default calling convention". Make sure that the calling convention is not set to CVF in the project properties (External Procedures). If it is, your use of a callback procedure will cause stack corruption. All IMSL callback procedures must be using the default (C) calling convention.
If you are using the default convention, then I suggest trying replacing:
with:
INCLUDE 'link_fnl_shared.h'
and see if this changes the behavior.
Steven_L_Intel1
with:
akrallis
with:
Hello Steve,
The workaround that you proposed has solved the AccessViolationException problem.
The above solution works without problems in a PC where Visual Studio 2008 and Intel FORTRAN with IMSL library are both installed .
When we try to use this dll library in a computer where the IMSL is not installed although we have we put the IMSL_DLL.DLL file in the same folder with the dll library we get an Unable to load DLL 'dll2.dll': The specified module could not be found error.
When we use the dependency walker tool we see that the following dependencies are missing:
LIBIFCOREMD.DLL
LIBMMD.DLL
LIBIFPORTMD.DLL
LIBGUIDE40.DLL
A solution to this problem could be to copy all the above dll files to the same directory whith the initial library . Is there a more efficient way to deploy a dll that makes calls to the IMSL library ?
Thanks in advance .
Steven_L_Intel1
I'm still somewhat skeptical that you have the calling conventions right. I suggested the DLL libraries because I've seen some problems in the past calling statically-linked DLLs from C# or VB.NET. I don't know why this is an issue.
Please do this. Right click on your Fortran DLL project, select Properties, Fortran, Command Line. Copy all of the command options shown and paste them into a reply here. I want to see what you're using.
akrallis
These are the command options:
/nologo /names:uppercase /module:"Release" /object:"Release" /c
I'm looking forward for your reply.
Steven_L_Intel1
Those are ALL the options shown?
To answer your earlier question, yes, you would need to copy the IMSL DLLs to the target system, ideally in a folder listed in the PATH environment variable. Your license allows you to do this as long as the purpose is not to provide IMSL functionality directly to users without a license. (If you use IMSL calls as part of your own application functions, that's fine.)
akrallis
Helo Steve ,
Yes all the options of the FORTRAN DLL project are "/nologo /names:uppercase /module:"Release" /object:"Release" /c" .
The problem remains even when we add the following dlls in the same folder as the executable (or the windows/system32 folder):
LIBIFCOREMD.DLL
LIBMMD.DLL
LIBIFPORTMD.DLL
LIBGUIDE40.DLL
The console application in C# still fails with the error " Unable to load DLL 'dll2.dll': Invalid access to memory location" .
From the dependency walker tool we see that the DWMAPI.DLL file can not be found .
Do you have any ideas or workarounds toinvestigate or solvethis issue ? My opinion is that it would simpler if we could use the static library of IMSL in order to build the dll but this path fails to call the callback function fcn of the d_ivpag function (call d_ivpag(ido, fcn, fcnj, t1, t2, y, tol=tol, param=param) ) .
Thanks in advance ,
George .
cneufeld
Hi George,
I posted a while ago about calling a Fortran function/subroutine from C#. There is an example project here:
http://software.intel.com/en-us/forums/showthread.php?t=52377
It is a simple fortran dll with 3 subroutines that are called from a C# program. You will likely have to rebuild the project. I used to test passing array and variables back and forth, as well as to test debugging inside the fortran code.
When I test the dll with dependancy walker, I get the same DWMAPI.DLL not found error. It is marked as a delay-load dll and I haven't had any problems using the dll on other machines.
You do need to install the Microsoft_VC80_CRT_x86.msm runtime library on a target machine. I found that the Intel DLL's where not enough.
I can't offer any assistance with the IMSL libraries though. Best of luck.
Cheers, Chad
Steven_L_Intel1
George,
Would you please post your new C# console app that calls the DLL calling IMSL? I want to try this myself but I don't know how you're calling the DLL.
akrallis
George,
Hi Steve ,
The ConsoleApplication1.rar contains the C# project ( Visual Studio 2008) . Please let me know in case you need any additional information.
Thanks in advance ,
George
Steven_L_Intel1
Well, I tried this and the program ran perfectly using the static libraries. Please attach an archive of your Fortran solution. ("Clean" it first to remove dlls and objects.)
akrallis
Hello Steve,
I have attached the Fortran dll project. Please note that when the C# project runs on a PC whereFortean withimsl productare installed, everything runs without a problem. On the other hand when we use the C# project on a computer with the Visual Studio 2008 (without Fortran and IMSL installed), we get the 'Unable to load DLL error'.
Thank you in advance
Steven_L_Intel1
I would expect that if you linked to the shared IMSL libraries that you would need to copy the IMSL DLLs onto that system. You are permitted to do so, with minor restrictions, by the license.
I'll try this version to see if there's a difference. I will comment that I am using the IMSL from version 11 - I don't have the older one installed anymore.
g_f_thomas
Quoting - akrallis
Hello Steve,
Isn't this a surreptitiously naked attempt to provide IMSL functionality to someone who hasn't a legitimate license? VNI are a clever bunch who rightly protect their technology.
Gerry
Steven_L_Intel1
I don't see that from what's been supplied. You are correct that simply providing a wrapper to IMSL for the use of developers not licensed for it violates the IMSL EULA. But calling IMSL from your own DLL isn't necessarily a problem as long as you are adding value.
g_f_thomas
The posted rar has no added value. It works if you distribute the IMSL licence though I wouldn't counsel that, but you never know, YMMV.
Gerry
akrallis
Hi Steve,
Have you tested the application under Fortran v10.1.025? Do you recommend to upgrade to Fortran v11?
