Update 2 Revised (11.1.048)
The cross-compilers (IA-32 to Intel 64 and IA-32 to IA-64) were rebuilt to correct an
issue where these compilers would not run on certain Windows 7* and Windows Server
2008* systems. Correctness of generated code is not an issue.
Microsoft Windows 7* was added as a supported operating system
_________________________________________
I suppose the 10.1 installer might have difficulties with straight win7. If your system is capable of XPM, you could run inside virtualization. Then again, you might have a very old or new model CPU where the 10.1 installer didn't run into difficulty.
11.1.048 is the minimum version supported on Windows 7. Earlier versions may or may not work.
