29488 Discussions
Intel Fortran Compiler 11.0--Installation configuration - Missing Critical Pre-requisite
Anonymous21
Intel Fortran Compiler 11.0 are being installed. However, thereis this problem, as follows,
Step no: 4 of 7 | Installation configuration - Missing Critical Pre-requisite
The following required for installation commands are missing:
g++
1. Finish with prerequisites and back to Critical Pre-requisites dialog
[default]
2. Back to Pre-requisite summary dialog
h. Help
b. Back to the previous menu
q. Quit
My operation system uses CentOS 5.
I also try to do following this command
[root@localhost l_cprof_p_11.0.074_ia32]# yum install g++
Loading "fastestmirror" plugin
Loading mirror speeds from cached hostfile
* adobe-linux-i386: linuxdownload.adobe.com
* base: centos.mirror.cdnetworks.com
* updates: centos.mirror.cdnetworks.com
* addons: centos.mirror.cdnetworks.com
* extras: centos.mirror.cdnetworks.com
Setting up Install Process
Parsing package install arguments
No package g++ available.
Nothing to do
I do not know what to do to solve this problem. because I am beginner for Linux opration system.
Could you let me know how to do?
TimP
If you haven't installed g++ development system, go to your CentOS software installation menu and correct that. You didn't say whether you are running 32- or 64-bit CentOS; I'm not sure CentOS x86_64 would have a menu installation for 32-bit g++.
Also, you didn't say if you are trying CentOS 5.0, which is inadvisable, and will make extra work, compared with an up to date version.
TimP
Anonymous21
Quoting - tim18
Thanks for your reply... I also double-checked it.
yjyincj
Quoting - hydrol88
I am having the same problem. My OS is Fedora 11. I installed gcc.i586 package by: yum install gcc.i586. What I got is :
g++
[default]
h. Help
q. Quit
Ron_Green
yjyincj
Thanks. I've read this article before I got error. When I type : gcc --version I got:
gcc (GCC) 4.4.0 20090506 (Red Hat 4.4.0-4)
Copyright (C) 2009 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
And When I type g++ --version I got:
bash: g++: command not found
Finally, I went by the silent install. This is what I got.
[root@yuejun l_cprof_p_11.1.046_ia32]# ./install.sh --silent ./intel_silent.ini
Warning: destination directory already exists. When installing C++ and Fortran
packages from the same package release into their default directories
(e.g. l_cproc_p_11.1.046 and l_cprof_p_11.1.046), you can ignore this warning.
I think it is installed successfully. But I am confusing why it can not be installed in another way.
Ron_Green
Quoting - yjyincj
It needs 32bit g++ also. There is a vague note on this that I'll fix in the document:
" yum install gcc
Likewise, go ahead and install g++ (this is not installed by default)"
so did you enter command: yum install g++
I will make this clear in the notes.
ron
yjyincj
" yum install gcc
ron
I thought g++ in part of gcc. This is what I got :
[root@yuejun IntelFortran]# yum install g++
Loaded plugins: fastestmirror, presto, refresh-packagekit
* fedora: astromirror.uchicago.edu
* rpmfusion-free: astromirror.uchicago.edu
* rpmfusion-free-rawhide: astromirror.uchicago.edu
* rpmfusion-free-updates: astromirror.uchicago.edu
* rpmfusion-nonfree: astromirror.uchicago.edu
* rpmfusion-nonfree-updates: astromirror.uchicago.edu
* updates: astromirror.uchicago.edu
Nothing to do
hellow world program is compiled suceessfully. But when I do another one:
program main
implicit none
real(4)::i
i=3.0
write(*,*)'i= ',i
stop
end program
I got error:
ifort: error #10310: Failed to enable trusted storage check for licensing: WARNING: Enable Trusted Storage failed (flexnet error code 2). Trusted Storage based license could
Ron_Green
Quoting - yjyincj
Nothing to do
program main
implicit none
real(4)::i
i=3.0
write(*,*)'i= ',i
stop
end program
I got error:
opps, my mistake, the yum command is:
yum install gcc-c++
No, g++ is not installed with gcc.
Did you put your license file ( .lic ) in /opt/intel/licenses/ folder?
ron
TimP
yum install gcc-c++
Well, that's a nice feature of certain other distros. Simply install C++ development system, get both gcc and g++. Select 32-bit option, automatically add 32-bit equivalents. But at some point, if installing other than default compilers, you do get into the requirement for gcc-c++, and Intel compilers do depend on the corresponding gcc and g++ both being present.
Install Intel C++, get both icc and icpc. Now at last we have also set environment variable for one Intel compiler, automatically get others of same version, if present, and also the performance libraries.
