29653 Discussions
Intel Fortran Compiler 11.1 and OpenMPI 1.4 bug - Inconsistent Output
oacikgoz
Hi everyone,
I'm going nuts with my code, because what is happening is beyond my comprehension. When I compile my code with -g option, or -check all, or -check bounds flag, the code runs perfectly fine, though, as you can guess, very slow.
Whenever I use any optimization flag, the code fails to run, gives random segmentation faults. More importantly, the code has something of this sort:
x(1)=...
x(2)=...
x(64)=...
When I add WRITE(6,*) x(1) at the end, it gives me a number totally different from what I set it to. (gives me zero) x is an allocatable array which is properly allocated to be of size 64.
Here are some technical details:
I do not have Intel C/C++ compiler and therefore OpenMPI was compiled with gcc, g++ and ifort combined, with no special flags. If I use gfortran, the code runs with no problems, regardless of the optimization level.
I also tried to use MPICH2 and still the problem persists. It's not specific to OpenMPI. There is a compiler bug in Intel Compiler, or, there is an incompatibility between GCC 4.2 and ifort.
Do you think that the problem would disappear if I use Intel MPI? What do you think is the root of the problem?
TimP
If you want to refer the question to the Intel MPI team, the HPC forum would be more suitable.
I have worked using ifort with both OpenMPI and Intel MPI, and don't recognize such a problem. write(6,*) isn't ideal, as it depends on undisturbed pre-assignment of unit 6, and it's possible for accidents like array over-runs to produce a result such as you report. I would use write(*,*) or write to a specific file. But all that doesn't seem directly related to your problem.
Array over-runs, or, more often, problems due to lack of data initialization, may be exposed with optimization turned on, and might be suppressed by -check even with the optimization level set. Sometimes, problems with uninitialized data and optimization respond to -zero -save (if you don't use threading together with MPI), in case that may help locate it. I would agree that when you first try -check, you would likely set -g and allow optimization to drop off.
