29654 Discussions
Intel Fortran Compiler Mac OS X optimization bug
oacikgoz
The following code gives me inconsistent results. It runs fine with optimization turned off.
The screen output with optimization is (sometimes quits with SIGSEGV)
2.122514567798456E-314 2.122514567798456E-314
0.826680222897825 2.122514567798456E-314
Without optimization, I get the right numbers
-0.999305041735772 1.783280721696433E-003
3.474791321139148E-004 1.783280721696433E-003
Here is the code
PROGRAM main
IMPLICIT NONE
INTEGER :: i
REAL(8), DIMENSION(:), ALLOCATABLE :: xt
REAL(8), DIMENSION(:), ALLOCATABLE :: wt
ALLOCATE(xt(64))
ALLOCATE(wt(64))
xt(1) = - 0.999305041735772139456905624346D+00
xt(2) = - 0.996340116771955279346924500676D+00
xt(3) = - 0.991013371476744320739382383443D+00
xt(4) = - 0.983336253884625956931299302157D+00
xt(5) = - 0.973326827789910963741853507352D+00
xt(6) = - 0.961008799652053718918614121897D+00
xt(7) = - 0.946411374858402816062481491347D+00
xt(8) = - 0.929569172131939575821490154559D+00
xt(9) = - 0.910522137078502805756380668008D+00
xt(10) = - 0.889315445995114105853404038273D+00
xt(11) = - 0.865999398154092819760783385070D+00
xt(12) = - 0.840629296252580362751691544696D+00
xt(13) = - 0.813265315122797559741923338086D+00
xt(14) = - 0.783972358943341407610220525214D+00
xt(15) = - 0.752819907260531896611863774886D+00
xt(16) = - 0.719881850171610826848940217832D+00
xt(17) = - 0.685236313054233242563558371031D+00
xt(18) = - 0.648965471254657339857761231993D+00
xt(19) = - 0.611155355172393250248852971019D+00
xt(20) = - 0.571895646202634034283878116659D+00
xt(21) = - 0.531279464019894545658013903544D+00
xt(22) = - 0.489403145707052957478526307022D+00
xt(23) = - 0.446366017253464087984947714759D+00
xt(24) = - 0.402270157963991603695766771260D+00
xt(25) = - 0.357220158337668115950442615046D+00
xt(26) = - 0.311322871990210956157512698560D+00
xt(27) = - 0.264687162208767416373964172510D+00
xt(28) = - 0.217423643740007084149648748989D+00
xt(29) = - 0.169644420423992818037313629748D+00
xt(30) = - 0.121462819296120554470376463492D+00
xt(31) = - 0.729931217877990394495429419403D-01
xt(32) = - 0.243502926634244325089558428537D-01
xt(33) = 0.243502926634244325089558428537D-01
xt(34) = 0.729931217877990394495429419403D-01
xt(35) = 0.121462819296120554470376463492D+00
xt(36) = 0.169644420423992818037313629748D+00
xt(37) = 0.217423643740007084149648748989D+00
xt(38) = 0.264687162208767416373964172510D+00
xt(39) = 0.311322871990210956157512698560D+00
xt(40) = 0.357220158337668115950442615046D+00
xt(41) = 0.402270157963991603695766771260D+00
xt(42) = 0.446366017253464087984947714759D+00
xt(43) = 0.489403145707052957478526307022D+00
xt(44) = 0.531279464019894545658013903544D+00
xt(45) = 0.571895646202634034283878116659D+00
xt(46) = 0.611155355172393250248852971019D+00
xt(47) = 0.648965471254657339857761231993D+00
xt(48) = 0.685236313054233242563558371031D+00
xt(49) = 0.719881850171610826848940217832D+00
xt(50) = 0.752819907260531896611863774886D+00
xt(51) = 0.783972358943341407610220525214D+00
xt(52) = 0.813265315122797559741923338086D+00
xt(53) = 0.840629296252580362751691544696D+00
xt(54) = 0.865999398154092819760783385070D+00
xt(55) = 0.889315445995114105853404038273D+00
xt(56) = 0.910522137078502805756380668008D+00
xt(57) = 0.929569172131939575821490154559D+00
xt(58) = 0.946411374858402816062481491347D+00
xt(59) = 0.961008799652053718918614121897D+00
xt(60) = 0.973326827789910963741853507352D+00
xt(61) = 0.983336253884625956931299302157D+00
xt(62) = 0.991013371476744320739382383443D+00
xt(63) = 0.996340116771955279346924500676D+00
xt(64) = 0.999305041735772139456905624346D+00
wt(1) = 0.178328072169643294729607914497D-02
wt(2) = 0.414703326056246763528753572855D-02
wt(3) = 0.650445796897836285611736039998D-02
wt(4) = 0.884675982636394772303091465973D-02
wt(5) = 0.111681394601311288185904930192D-01
wt(6) = 0.134630478967186425980607666860D-01
wt(7) = 0.157260304760247193219659952975D-01
wt(8) = 0.179517157756973430850453020011D-01
wt(9) = 0.201348231535302093723403167285D-01
wt(10) = 0.222701738083832541592983303842D-01
wt(11) = 0.243527025687108733381775504091D-01
wt(12) = 0.263774697150546586716917926252D-01
wt(13) = 0.283396726142594832275113052002D-01
wt(14) = 0.302346570724024788679740598195D-01
wt(15) = 0.320579283548515535854675043479D-01
wt(16) = 0.338051618371416093915654821107D-01
wt(17) = 0.354722132568823838106931467152D-01
wt(18) = 0.370551285402400460404151018096D-01
wt(19) = 0.385501531786156291289624969468D-01
wt(20) = 0.399537411327203413866569261283D-01
wt(21) = 0.412625632426235286101562974736D-01
wt(22) = 0.424735151236535890073397679088D-01
wt(23) = 0.435837245293234533768278609737D-01
wt(24) = 0.445905581637565630601347100309D-01
wt(25) = 0.454916279274181444797709969713D-01
wt(26) = 0.462847965813144172959532492323D-01
wt(27) = 0.469681828162100173253262857546D-01
wt(28) = 0.475401657148303086622822069442D-01
wt(29) = 0.479993885964583077281261798713D-01
wt(30) = 0.483447622348029571697695271580D-01
wt(31) = 0.485754674415034269347990667840D-01
wt(32) = 0.486909570091397203833653907347D-01
wt(33) = 0.486909570091397203833653907347D-01
wt(34) = 0.485754674415034269347990667840D-01
wt(35) = 0.483447622348029571697695271580D-01
wt(36) = 0.479993885964583077281261798713D-01
wt(37) = 0.475401657148303086622822069442D-01
wt(38) = 0.469681828162100173253262857546D-01
wt(39) = 0.462847965813144172959532492323D-01
wt(40) = 0.454916279274181444797709969713D-01
wt(41) = 0.445905581637565630601347100309D-01
wt(42) = 0.435837245293234533768278609737D-01
wt(43) = 0.424735151236535890073397679088D-01
wt(44) = 0.412625632426235286101562974736D-01
wt(45) = 0.399537411327203413866569261283D-01
wt(46) = 0.385501531786156291289624969468D-01
wt(47) = 0.370551285402400460404151018096D-01
wt(48) = 0.354722132568823838106931467152D-01
wt(49) = 0.338051618371416093915654821107D-01
wt(50) = 0.320579283548515535854675043479D-01
wt(51) = 0.302346570724024788679740598195D-01
wt(52) = 0.283396726142594832275113052002D-01
wt(53) = 0.263774697150546586716917926252D-01
wt(54) = 0.243527025687108733381775504091D-01
wt(55) = 0.222701738083832541592983303842D-01
wt(56) = 0.201348231535302093723403167285D-01
wt(57) = 0.179517157756973430850453020011D-01
wt(58) = 0.157260304760247193219659952975D-01
wt(59) = 0.134630478967186425980607666860D-01
wt(60) = 0.111681394601311288185904930192D-01
wt(61) = 0.884675982636394772303091465973D-02
wt(62) = 0.650445796897836285611736039998D-02
wt(63) = 0.414703326056246763528753572855D-02
wt(64) = 0.178328072169643294729607914497D-02
WRITE(*,*) xt(1),wt(1)
xt=(xt+1.0D0)*0.5D0
END PROGRAM main
Kevin_D_Intel
At optimization, the program fails with 11.1.067 related to the known incompatibility with linker in Xcode 3.2.2 and later. See this sticky post more details about the known linker incompatibility.
Your program runs correctly at optimization when using the advertised work around (see below): -use-asm
Your program also produces correct results without this work around when using the latest 11.1.089 update (see below) which contains a patch for this known linker incompatibility.
Using use-asm work around with 11.1.067:
$ ifort -V u78427.f90 -use-asm
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20090827 Package ID: m_cprof_p_11.1.067
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
Intel Fortran 11.1-2582
@(#)PROGRAM:ld PROJECT:ld64-97.2
Library search paths:
$ ./a.out
No work around needed with 11.1.089:
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100806 Package ID: m_cprof_p_11.1.089
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
Intel Fortran 11.1-2755
$ ./a.out
oacikgoz
Could someone please confirm this bug?
If you decide to do so, compile the above code once with flag -O0 and once with no flags. Default optimization screws it up.
I'm curious if the linux compiler has the same problem.
david_car
Works fine on Linux.
david@server:/tmp$ ifort --version
ifort (IFORT) 11.1 20100806
david@server:/tmp$ ifort --versionifort (IFORT) 11.1 20100806Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
oacikgoz
Very interesting, maybe it's a bug that is fixed. I noticed I have a different version of ifort
ifort (IFORT) 11.1 20090827
I will download the newer version and give it a shot.
Thanks!
Kevin_D_Intel
$ ./a.out
$ ./a.out
oacikgoz
Thank you very much for your input! I spent so much time trying to fix my code. It ended up being a bug in the compiler+xcode. Now it all makes sense.
