Stack overflow
bcartolos
Hi all,
I am coding a little fea solver. I use imsl to solve the stiffness matrix but I get a stack overflow error when I refine my solution (The program works well with a limited number of nodes, when I attempt to solve more exact solution the error appears)
The error I get is this:
Unhandled exception at 0x000000014023e1b7 in Problema1.exe: 0xC00000FD: Stack overflow.
The line that is causing the problem is located in a subroutine called from the main program
[fortran]Desp(DI) = Rigidez(DI, DI) .ix. F(DI)[/fortran]
Rigidez, Desp and F are variables declared in a module called Globals
[fortran]real(8), allocatable:: Rigidez(:,:)
real(8), allocatable:: Desp(:)
real(8), allocatable:: F(:)
[/fortran]
DI is a vector declared inside the subroutine and the values are set by another subroutine
[fortran]integer,allocatable:: DI(:)
call DIncognitas(DI, NDI)[/fortran]
Best Regards
Les_Neilson
Valued Contributor II
You can, if you wish, increase the stack size in the project settings :
Project->Properties->Linker->System-> Stack Reserve Size
You can also force temporary arrays to be allocated on the heap instead of the stack
Project->Properties->Fortran->Optimization->Heap Arrays 0 (zero)
Les
bcartolos
Thank Les for your reply
How large should the stack reserve be?
and also Changing the stack size will not affect performance?
Best Regards
Les_Neilson
I just took a quick look at one of our (smaller) projects and it is set to 4,000,000
(another, mixed language project, sets the stack at 8Gb!)
I doubt you will notice any performance issues unless you profile the code.
Les
bcartolos
Thank you very much for your answer
Best Regards
bcartolos
It's me again
I try to keep refining my solution but another error appeared:
[bash]forrtl: severe (41): insufficient virtual memory[/bash]
Can that restriction be circumvented?
Best Regards
The stack is limited to 1GB in Windows. You may be bumping into the 2GB addressable limit in 32-bit Windows. How much data are you trying to allocate? Are you building a 64-bit application? The exception address in the first post suggests you are.
