29653 Discussions
Intel Fortran Compiler file error message
deepakp1387
If anyone else has ever encountered the following error and knows the reason, Please Help!
Library that generated this error was compiled in the Intel Fortran 11 version.
df: error: Unknown switch: '/O3'
Thank You
Aubrey_W_
I'll move this thread to the Intel Fortran Compiler forum, where one of our technical consulting engineers can assist you.
Aubrey W.
Intel Software Network Support
The "df" command is for Compaq Visual Fortran and indeed that compiler did not recognize an /O3 switch. The Intel compiler command, ifort, will recognize this.
