Intel Fortran Error
Oana_Raluca_M_
Error: A license for FCompW is not available now (-96,491).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd.exe process and an INTEL.exe process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
1. Trusted Storage
2. 28518@BUC-PLAT-APP02
3. C:\Program Files (x86)\Common Files\Intel\Licenses\COM_W__FOR_xxx_xxxxxxx.lic
4. C:\Program Files\Common Files\Intel\Licenses
5. c:\PROGRA~2\intel\COMPOS~1\bin\ia32\*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
ifort: error #10052: could not checkout FLEXlm license
TimP
same question was posted also on Windows forum
See https://software.intel.com/en-us/forums/topic/518485
