error for floating licence
Oana_Raluca_M_
Hello!
I got the next error and I don't know what to do:
Error: A license for FCompW is not available now (-96,491).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd.exe process and an INTEL.exe process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
1. Trusted Storage
2. 28518@BUC-PLAT-APP02
3. C:\Program Files (x86)\Common Files\Intel\Licenses\COM_W__FOR_Fxxx_xxxxxxxx.lic
4. C:\Program Files\Common Files\Intel\Licenses
5. c:\PROGRA~2\intel\COMPOS~1\bin\ia32\*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
ifort: error #10052: could not checkout FLEXlm license
Thank you!
TimP
If you need someone at Intel to look up your license status, you should get faster response at:
https://software.intel.com/en-us/forums/intel-software-development-products-download-registration-licensing
It looks like the license found during the search may be too old for the Fortran release, or, as the message said, you may have all the licenses already checked out.  Checked out licenses should return to availability after a few minutes of being idle.
If you can log in to your account at https://registrationcenter.intel.com you can check your licenses and have a fresh copy emailed.
As it says in the error message, though I admit the message is quite verbose, "A connection to the license server could not be made.". This means that the compiler could not contact the license server on node BUC-PLAT-APP02. You will have to talk to your system administrator to determine why that is. It could be that the license server is not running on that server, or there is a network problem.
