29651 Discussions
Intel Fortran Integration with Microsoft Visual Studio
Moel
I am using a software (Aspen) which requires both Intel Fortran and Microsoft Visual Studio in order to run my simulation.
I downloaded Microsoft Visual Studio Community 2015 and Intel Parallel Studio XE 2019 (I checked to see if those versions can be integrated and they can). Firstly, I installed Visual Studio (all boxes checked during installation) and then Intel Parallel Studio XE 2019. Then I checked if the installation succeded and it did, as seen below:
37 IVF14_VS12   OK    Intel Fortran 2019 and Microsoft Visual Studio 14/2015
Next step is compiling the fortran code, so I place it in "C:\UserModels", then I open the Simulation window and type :
C:\ProgramData\AspenTech\Aspen Plus>cd ..
C:\ProgramData\AspenTech>cd ..
C:\ProgramData>cd ..
C:\>cd UserModels
C:\UserModels>aspcomp usrknt.f
And I get the following message :
ASPCOMP: Warning! Intel Fortran compiler ifort.exe not found in %PATH%
'ifort.exe' n'est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
  Error in compiling preprocessed file: Check compile.log
I already followed these steps (https://software.intel.com/en-us/articles/troubleshooting-fortran-integration-issues-with-visual-studio/) to repair but it still doesn't work.
How to fix this problem? I appreciate if someone could explain to me in a simplified way because I am no software engineer and I have no idea how to fix this!
Thanks in advance.
Steve_Lionel
This is an issue with ASPENPLUS, not Intel Fortran. You'll need to ask Aspen support.
