29268 Discussions
Intel Fortran compiler installation problem in Ubuntu 11.04
sukantamech
Dear sir,
I am a new user in ubuntu 11.04 (Linux). I have installed krite for editing, now I want to install Fortran compiler, I have downloaded the software Intel Fortran Composer XE for Linux* (formerly Intel Fortran Compiler Professional Edition for Linux*) non-commercial version of 64bit (351 mb) from Intel website.
But I don't know how to install. Please kindly assist me in the installation steps.
Sukanta Roy.
sukantamech07@gmail.com
sukantamech
Hi..
I am using 64bit ubuntu 11.04 destop. I have just recently installed ifort, Intel composerXE12. just after installation, i have given the following command... but facing problem in that...
Please suggest me what to do.....!!! (sukantamech07@gmail.com)
sukanta@Energy:~$ /opt/intel/composerxe-2011.5.220/bin/compilervars.sh intel64
[: 121: intel64: unexpected operator
ERROR: Unknown option 'intel64'
Syntax:
/opt/intel/composerxe-2011.5.220/bin/compilervars.sh [MKL_interface] [mod]
must be one of the following
ia32 : Set up for IA-32 target
intel64 : Set up for Intel 64 target
mic : Set up for Intel MIC target
mod (optional) - set path to MKL F95 modules
MKL_interface (optional) - MKL programming interface for intel64
Not applicable without mod
lp64 : 4 bytes integer (default)
ilp64 : 8 bytes integer
sukanta@Energy:~$
Ron_Green
source /opt/intel/bin/compilervars.sh intel64
you need the source command from bash. To confirm you use the bash shell:
echo $0
that's a zero or zed after the dollar sign. This prints your shell, which should be "bash"
ron
TimP
Use compilervars.csh if running tcsh or similar shell
sukantamech
Thanks Ron for your support. Now my fortran is running..
