29375 Discussions
Intel Fortran fails to recognize the PRIVATE attribute of a type-bound procedure in a base type when it is extended.
FortranFan
Consider the following simple example:
MODULE b
   IMPLICIT NONE
   !.. Private by default
   PRIVATE
   TYPE, ABSTRACT, PUBLIC :: A_t
      PRIVATE
      !.. Private fields
      INTEGER :: m_A
   CONTAINS
      PRIVATE
      !.. Private methods
      PROCEDURE(IFoo), PASS(This), DEFERRED :: Foo
   END TYPE A_t
   TYPE, EXTENDS(A_t), PUBLIC :: B_t
      PRIVATE
   CONTAINS
      PRIVATE
      !.. Private methods
      PROCEDURE :: Foo => BFoo
   END TYPE B_t
   !.. Abstract Interface for class methods
   ABSTRACT INTERFACE
      !.. Initialize EosClass
      PURE ELEMENTAL SUBROUTINE IFoo(This)
         IMPORT :: A_t
         !.. Argument list
         CLASS(A_t), INTENT(INOUT) :: This
      END SUBROUTINE IFoo
   END INTERFACE
CONTAINS
   PURE ELEMENTAL SUBROUTINE BFoo(This)
      !.. Argument list
      CLASS(B_t), INTENT(INOUT) :: This
      This%m_A = 0
      RETURN
      END SUBROUTINE BFoo
END MODULE b
MODULE c
   USE b, ONLY : B_t
   IMPLICIT NONE
   PRIVATE
   TYPE, EXTENDS(B_t), PUBLIC :: C_t
      PRIVATE
      INTEGER :: m_C
   CONTAINS
      PRIVATE
      !.. Private methods
      PROCEDURE, PASS(This), PUBLIC :: Bar
   END TYPE C_t
CONTAINS
   PURE ELEMENTAL SUBROUTINE Bar(This)
      !.. Argument list
      CLASS(C_t), INTENT(INOUT) :: This
      This%m_C = 0
      CALL This%Foo() ! <-- Foo is PRIVATE to module b; compiler should flag
                      !     an error
      RETURN
   END SUBROUTINE Bar
END MODULE c
Intel Fortran compiler  - version 13 (XE 13.1.1.171) and 2015 Beta - fails to flag an error at line 109 that the invoked method Foo is PRIVATE to MODULE b.  It compiles the code with no errors.
I think this is a compiler bug.  Can someone from Intel please check and do the needful?
Thanks. Escalated as issue DPD200359178.
