29648 Discussions
Intel Fortran runtime libraries with msi
ihabi__mallyna
1) We are planning on using the msi file that they provide (ww_ifort_redist_intel64_2019.0.117.msi) to install the Intel Fortran runtime libraries. Is there any documentation we could get that details command line switches for things like running silently, etc.?
2) Programmatically. what should we be checking to determine if the Intel Fortran runtime is already installed? We would like to have a registry key that we could check if possible.
Stacey_C_
I need this information too.  It seems that each new version of the ifort runtime has a different registry key.  It is hard to check whether there is already a later or earlier version installed, if they use different registry keys.
