Intel Fortran supports the general purpose GPU programming?
dingjun_chencmgl_ca
HI, everyone,
I want to know if the latest INTEL Fortran compiler supports the GPGPU(the General Purpose Graphic Processing Unit) programming. Currently our oil reservoir simulators are implemented with the Intel Fortran. To  offload computationally intensive componets of the simulator to the GPGPU, is Intel Fortran able to support and compile the GPU codes together with previously existing Simulator Frotran Codes?  Can the GPU code be compiled and run or debugged on the CPU before generating the acceleration kernels for the GPU? If so, it is very useful to speed-up the development process.
I look forward to hearing from Intel and thanks in advance.
Dingjun
James_T_Intel
Hi Dingjun,
I'm going to move this to the Intel® Fortran Compiler forum, as that is a more appropriate place to ask this question.
I also recommend looking into the Intel® Xeon Phi" Coprocessor.  The coprocessor is supported by the Intel® Fortran Compiler as well as other Intel® Software Development Products.  Your code will not have to change significantly in order to take advantage of the coprocessor's offload capability, and some tools also have an automatic offload capability so that you won't have to make any changes in order to take advantage of the coprocessor.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
Ron_Green
The Intel Compilers only support Intel(R) Xeon Phi(TM) Coprocessors. For more information, look here:
The main web portal for Intel(R) Xeon Phi(TM) Coprocessor
Compiler Methodology for Intel(R) Xeon Phi(TM) Coprocessor
Casey
Check out FortranCL, which works with the intel compiler. https://code.google.com/p/fortrancl/
dingjun_chencmgl_ca
Intel Fortran complier supports OpenMP directives, I want to know if the Intel Fortran complier supports the OpenACC directives for GPU accelarator?
If Intel Fortran complier supports both directives programming, it would be very helpful for  us to program with both OpenMP and OpenACC directives in our existing Fortran codes.
TimP
 next major release would introduce open mp 4.0 agreed successor to open acc
Anonymous66
Valued Contributor I
The current compiler version already includes support for the offload and SIMD syntax for OpenMP* 4.0 Technical Report 1. There have been some changes for offloading between Techinical Report 1 and the current revision of the OpenMP 4.0 standard, RC2. As Tim said, these will be implemented in the next major release.
dingjun_chencmgl_ca
Thanks indeed for your reply. Hopefully the Intel Fortran Compiler ifort.exe can support both OpenMP and OpenACC directives soon. Thererfore, this could cause a huge convenience in programming to improve the parallel performance of our reservoir simulators. The use of GPU accelerator is popular now and we are looking forward to your latest Intel Composer XE 2013/2014 version supporting OpenACC directives.
Anonymous66
To be clear, we only support the offloading to Intel® Xeon Phi™ Coprocessors in the next release. We have no current plans to support offloading to other accelerators.
dingjun_chencmgl_ca
My only concern is whether or not the future Intel Fortran Compiler is going to support the OpenACC directives just like it right now is supporting the OpenMP directives. Intel® Xeon Phi™ Coprocessors could be our option as long as the Intel Fortran Compiler supports the OpenACC directives. This is not a problem.
TimP
Please read the public documentation on OpenMP 4.0 RC2 so as to understand the modifications you would need to go from current OpenACC into the future.   The standard is intended to support all devices currently covered by OpenACC and OpenMP.
dingjun_chencmgl_ca
I just read the Intel Xeon Phi Coprocessor Developer's Quick Start Guide for Windows Host, and was told that
" The operating system (OS) supported and validated on the host are: Windows 7 Enterprise SP1 and Windows Server 2008 R2 SP1".
But Windows 7 Professional is installed on my computer. My question is as follows:
Is it a mandatory for the Windows Enterprise to be installed as OS?
Kevin_D_Intel
As per the instruction on where to take issues under the Windows* early enabling announcement (http://software.intel.com/en-us/forums/topic/392264), please re-post your question under the Intel® Many Integrated Core Architecture (Intel MIC Architecture) forum at: http://software.intel.com/en-us/forums/intel-many-integrated-core
Thank you
Steven_L_Intel1
We have no plans to support OpenACC directives.
