29487 Discussions
Intel Fortrtan Compiler v.2022.1.0 Unable to complete installation
dj1967
I am trying to install the component, both offline and online installation, but no luck...
The error that i get is: intel.oneapi.win.compilers-common.ide.common_vs2019, name: IDE Common for Visual Studio 2019, version: 2022.1.0-256.
Error: Sequence execution failed.
I have already uninstall and re-install VS 2019.
Is there something else that i can try?
Steve_Lionel
Here's what worked for me when I had that issue. Make sure you follow this carefully and don't skip any steps:
Note: We would recommend you make sure that all Microsoft Visual Studio instances are uninstalled, by using the InstallCleanup.exe from the previously (and below) provided link.
Link: https://docs.microsoft.com/en-us/visualstudio/install/uninstall-visual-studio?view=vs-2022
  • Check & make sure that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does NOT exist anymore. If it was not removed with Microsoft Visual Studio for some reason, please unregister the DLL using
'REGSVR32 /U C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll'
command in Command Prompt as Administrator, and then rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll so the Intel® Installer can't load it.
  • Try uninstalling the Intel® oneAPI toolkit now.
Now reinstall Visual Studio and the oneAPI toolkit.
Steve_Lionel
dj1967
lewist57
I have followed the advice given above, and reinstalled VS 2022 Community with C++ options checked.  When installing the latest Fortran Classic compiler (2022.2), either online or off line, I get
Removal of component has failed
Component id: intel.oneapi.win.compilers-common.ide.common_vs2022, name: IDE Common for Visual Studio 22, version 2022.0.0-161
Suggestions?
Devorah_H_Intel
Are you upgrading from earlier oneAPI or PSXE version? If yes then follow these steps:
To upgrade from Intel® Parallel Studio XE or previous versions of Intel® oneAPI products to Intel® oneAPI 2022.1.3 and higher:
  1. Close any running Intel installers.
  2. Uninstall all Microsoft Visual Studio instances and Visual Studio installer.
    Important: Make sure that C:\ProgramData\Microsoft\VisualStudio\Setup\x86\Microsoft.VisualStudio.Setup.Configuration.Native.dll does not exist anymore. If it was not removed with Microsoft Visual Studio for some reason, unregister the DLL using the
    command in command prompt as administrator and rename the file to Backup_Microsoft.VisualStudio.Setup.Configuration.Native.dll, so that the Intel installer could not load it.
  3. Uninstall previous versions of Intel® Parallel Studio XE and Intel® oneAPI products.
  4. Install the required Microsoft Visual Studio products back.
  5. Install Intel® oneAPI 2022.1.3 or higher. Do not try to install previous versions of Intel® oneAPI or Intel® Parallel Studio XE products.
https://www.intel.com/content/www/us/en/developer/articles/technical/vs2022-and-oneapi-install-issue.html
lewist57
Alas, these are the exact steps that I have tried with no success.
I have noticed that on the 3 PCs that I have installed the compiler with VS, the first installation goes fine, but if I update either Visual Studio or the Fortran compiler, the installation does not work.
Wen-TUD
when I followed the steps, I encountered error after finishing installing, see attached log file. thanks,
Wen
Barbara_P_Intel
@Wen-TUD Please ask your question on the oneAPI Registration, Download, Licensing and Installation Forum. Here's the link.
lewist57
and Malwarebytes protection has been turned off prior to installation, no difference.
lewist57
And now for the rest of the story (you have to be a certain age to recognize the origin of that phrase)
I am sure that i skipped a very important step : i did not uninstall the compiler from VS before upgrading. I have subsequently completely removed the compiler and then VS, then installed latest versions of VS and the compiler, working perfectly. Hope this helps someone else.
