Intel Function Sample
JohnNichols
Honored Contributor I
I was looking at your function documentation today.
  FUNCTION ROOT(A)
    X  = 1.0
    DO
      EX = EXP(X)
      EMINX = 1./EX
      ROOT  = X - ((EX+EMINX)*.5+COS(X)-A)/((EX-EMINX)*.5-SIN(X))
      IF (ABS((X-ROOT)/ROOT) .LT. 1E-6) RETURN
      X  = ROOT
    END DO
  END
Unless I am mistaken and I ran it a few times, A > 2 for X to exist.   It just goes in an endless loop with A < 2 and runs into nan, but does not stop.
cosh(x) according to Wikipedia has a minimum of 1 at X = 0 and it increases faster than cos(x) decreases.
  FUNCTION ROOT(A)
if(A < 2.000) then
stop  "A has to be greater than 2"
endif
    X  = 1.0
    DO
      EX = EXP(X)
      EMINX = 1./EX
      X  = ROOT
    END DO
  END
 Just a thought.
Barbara_P_Intel
@JohnNichols, it took some digging, but we found the example you pointed out! I filed a bug report on the Fortran DGR (Developer Guide and Reference), DOC-10256. I added an IF/THEN/ELSE/ENDIF.
Thanks for reporting this.
JohnNichols
@Barbara_P_Intel , thanks.
I was using the function as a sample and the blasted thing disappeared to infinity and beyond.  So it took a few minutes to track down the problem.  The issue is the interesting shape of the cosh function.
I am sorry I will provide a link in the future.
Barbara_P_Intel
A new Fortran Developer Guide and Reference was recently published. The error in the example code is fixed.
The tech writer says, "Thank you for pointing this out!"
JohnNichols
Barbara:
Thank the tech writer for their kind words.  I showed the comment to my 15 year old daughter and she said even Santa is useful once a year.
She has a way with words, she did not get it from me.
Note this morning on VS 2019 - please upgrade as you only get security fixes.
John
mecej4
Here is the current link to the page in question: FUNCTION . A plot of the function can be viewed using this Wolfram Alpha link.
jimdempseyatthecove
mecej4 (or Steve),
Is there a way for a UDT contained procedure function to be used on the LHS of = that returns a reference to an array as opposed to a scalar? And which subsequently can be indexed;
  obj%func(i) = ...
IOW (i) is not an argument to the function but rather is an index into the returned array.
Note, if instead, the function is written to accept the index as an argument and return a reference to a cell within the (hidden) array, this works.
Jim Dempsey
edit:
block
  real, pointer :: temp
  temp => obj%func
  temp(i) = ...
end block
Works, but is not elegant.
Jim
Steve_Lionel
No, you can't index a function reference.
